AC stick welder vs. MIG welder
Lynn Kasdorf- L
02-28-2002 07:19:39
I have a really nice Millermatic 250 MIG welder that I use all the time. And I was recently given a Century 230A AC stick welder.
The MIG was my first welder- I have never used a stick welder. My question is- are there things I can do with an AC stick welder that I can't do with the MIG?
One thing that comes to mind is using it to heat metal with a carbon stick. (where can I get this, btw?) Are there special welding rods for doing, say, aluminum? I know I can theoretically do aluminum on my MIG if I get different gas, a new liner, etc. But if there was a way to do a quick aluminum weld with the stick welder, that would be great.
Or, any other advantages of the "buzz box"?
Mr. Weld(TX)
03-08-2002 09:23:21
 Re: AC stick welder vs. MIG welder in reply to Lynn Kasdorf- Leesburg, VA, 02-28-2002 07:19:39
The first difference I can think of is the ability for the arc welder to weld outside. The mig, unless you are using a flux-covered wire, will not weld outside. The wind will blow the CO2 away from your cone, and the weld will look terrible.
BUT for all purpose shop or garage welding, I prefer the mig. It's speed and the maintenance free weld (no slag to knock off before painting) is nice.
Bluelite
03-06-2002 16:11:11
The carbon pencils can be obtained at:
[email protected]
They are item 1252 Arc Air Electrode.
5/16 rods are 50 sticks per box @ a cost of $25.50/bx I think.
tractor rebuilder oklahoma
03-01-2002 06:47:16
The cracker box is a great thing to have around if for nothing else quick repairs and cast iron welding. But for most welding use the MIG. As long as you replace the liner with a new one when you weld aluminin the standard lead works fine, I keep a spare just for aluminin welding and when it starts to bind up use it for steel. I am using a Miller 185 and have not needed a Spool gun as of yet.
bbott
02-28-2002 20:03:42
The big advantage of the buzz box over the wire machine is quick change of rods for different purposes, and the incredible variety of rod types and diameters available.
For welding under a wide variety of conditions, you can't beat a stick for quick set-up. Of course, a wire machine beats a stick hands down for extended welding. It all depends on what your needs are I guess, I'd like to have a MIG in addition to my stick. Oh, and that plasma cutter too.
old bones
02-28-2002 07:39:18
i don't know much about mig, but i do know that you cannot weld aluminum with a stick AC welder. you need an ac/dc welder for that ( i run dc reverse polarity for aluminum). i don't think you can beat a stick welder for welding old steel with the right rods. my 2 cents.
Mark Kw
02-28-2002 08:36:23
 Re: Re: AC stick welder vs. MIG welder in reply to old bones, 02-28-2002 07:39:18
The AC stick machine is handy to have around because using 6013LV you will get a nice bead on heavier steels. Also great for repair of rusted metal without needing to clean spotless as with the mig.
As for aluminum, stick rods are useless. All they do is make a mess out of things. The welds are ugly and don't have much stength. If try to do a proper repair after a stick has been used, you have to remove all of the stick weld and area effected by it or you won't get a good repair.
The Millermatic 250 is an excellent runner of aluminum wire HOWEVER, you must use a spool-o-matic 30A spool gun for it. Depending upon the age of your 250, it may or may not have the required circuit board to plug the 30A into. If it does, you will have a connector on the upper right corner (facing control panel of machine), if it does not have the module board, you will see a rectangular blank off panel in that area. The board costs around $90 and is easy to intsall but requires removing the outer case of the machine.
Don't know current pricing on the 30A gun but best guess would be around $500. Trying to push wire through the whip is like trying to push a rope up a pipe. All it does is jam in the liner and birdnest in the drive wheels. Run 100% argon, reverse polarity. My machine runs 3/64" wire excellent at 18 to 21 volts with wire speed set on 2.5 to 3.5 (bottom of the grip on the 30A).
Miller also makes a push - pull assembly that uses the drive wheels in the machine to push while a 30A gun without the spool holder is attached to the whip. These work great but are costly to set up and you loose the steel wire capability without removing all the AL equipment from the machine. For this, the 30A is the way to go if you got the work to justify the costs.
That AC welder will also do a decent job with 6011 and 6010 rods too. All depends on how smooth the output is and what the run circuit voltage as to how well it'll weld with certain rods. Some AC machines will even lay a half decent bead with 7014 and 7018 while others will not even maintain a stable arc. As for using the carbon rods, this was the old way of doing galv sheet steel. Sharpen the carbon in a pencil sharpener then draw the arc with the welder and either do lap welds or use a bare filler rod. It worked but if you get some Esab coreshield 11 for your mig, it'll do the same thing faster and better. CS-11 runs without gas and on strait polarity (electrode negative).
chuck
07-14-2004 19:52:27
 Re: Re: Re: AC stick welder vs. MIG welder in reply to Mark Kw, 02-28-2002 08:36:23
Help! I am handy but not really wise on welding. I won't do much of it--just repairs around the house and shop, probably 1/8 steel, no really light metal so I don't need a cadillac--besides I am 62 years old and I doubt if I can outlive the welder. The question is: I just bought a Chicago Electic 80/160 AC 220v. welder--got it at a clearance at (sorry) Harbor Freight for $90.00.
I usually buy good tools, but since this is for occasional use thought this might be ok.
Would really appreciate your input and candid opinions. Thanks very much
