Removing scale and rust HELP!
Jeff May
02-26-2002 20:53:16
I recently aquired several expansion chambers for an old go kart I'm restoring. Question, How can I remove the rust from inside these pipes, I can't sand blast, because I may not get all the sand out and it may find its way back into the motor.
Is there a way to submurse these into a solution and let the rust disolve or be removed?
Thanks in advance,
Neal in NM
02-28-2002 18:40:17
 Re: Removing scale and rust HELP! in reply to Jeff May, 02-26-2002 20:53:16
You are looking for TREACLE. Treacle is a mixture of Molasses and water. I can't remember the dilution but I think it is four to one. Soak the part in the treacle for about a week or two and no more rust. Neal
LarryG
02-27-2002 04:18:42
Sounds like an application for some electrolysis action - look in the archives, there's been discussion in the past.
T_Bone
02-27-2002 01:51:13
Hi Jeff,
Sure is buts it's really expensive and difficult to use. LOL
Vinegar disolves rust! doesn't matter what kind of vinegar. Just rinse with water then heat dry then oil/paint to keep from rusting until used.
Depending on how thick the rust is, a couple days soaking would be normal. Turns the rust into a black oxide goo.
T_Bone
