Cutting Torch Question
Tom
02-26-2002 19:00:47
My question is when cutting a piece of metal like cutting a piece of angle iron in half the metal gets hot and it warps how can you make a cut like this with a regular torch with out it warping? Should you cut a inch or two at each end and let it cool and then cut some more till you have it cut? I know that a plasma cutter would work good for this but I don't do enough to justify buying one What I am doing is cutting out bad rusted spots and welding a new piece in on some of my restoration projects Any help would be greatly appreciated. Thanks
Trucker
03-09-2002 22:04:37
 Re: Cutting Torch Question in reply to Tom, 02-26-2002 19:00:47
If this angle is kind of thin like 1/4 or so you might try this,turn one leg of it up,heat right on top,when it gets ready hit the oxygen straight down.A torch can blow a hole through 4 0r 5 inches of steel,it can cut one leg of an angle in just a little bit,so it shouldnt warp before you get it cut.If you need to be a little more accurate,when you heat it up,angle the head so it heats about 1/3 of the way down the line,hold it at that angle and when you hit the oxy it will burn real fast about halfway down the line before you even have to move it.
Tim B
02-28-2002 10:20:59
To Mark and T_Bone,
Just to say thanks, recently bought a ace/oxy torch set up (cutting is one thing, I'm trying to get the hang of welding with it ! ??), I'm learning from all the post you guys are nice enough to write-up - now I just need mor time to practice!
Your Welcome....T_Bone nt
03-02-2002 10:29:54
 Re: Re: Cutting Torch Question in reply to Tim B, 02-28-2002 10:20:59
T_Bone
02-27-2002 01:38:01
Hi Tom,
From the info you gave, it would have been nice to know material type and thickness, tip size, gas used, your preheat flame is way to hot and or the tip is too large and dirty or both.
Common steel will rust in layers thus creating a void between the layers. As you try and cut thru the layers the metal will pop spit and sputter so a guy will tend to turn the preheat up and that seams to help but doesn't. What happens is the voids creates a cold spot and your cutting flame dies out thus creating the poping action. The best method is too let up on the oxygen blow and stop forward movement let the preheat catch up too the cold spots then adding cutting oxygen and continuing on.
On cutting sound soild angle iron I found it best to turn the angle iron over to where both legs are resting on the support table with the center web up or 1/2 of diamond facing up. Start cutting from the edge of one leg towards the center of the angle iron 90 and just blow thru the heavy rib(web) 90 and stop, then start cutting again from the opposite leg toward the center rib 90 until cut. If you don't blow thru that heavy part of the web 90 before stopping then the cut will be ragged and with alot of slag. Just as you get to that web part of the 90, slow the forward speed just alittle to let your preheat flame catch up but do not let up on the oxygen.
Setting a oxy/acet torch flame for cutting. Clean the tip preheat orifices(the outside holes) then clean the center cutting orifice(center hole), then clean the tip face, then reclean the preheat and cutting orifices. If you clean the tip this way it won't plug up the orifices.
Next turn on the acetylene and set the flame just where the gas starts to feather then add oxygen to where the preheat cones are sharp and pointed, this is an oxidizing preheat flame. If the preheat cone flames are not all the same height from the tip face and or ragged the they need to be recleaned. If the acetylene flame leaves the tip face then you have too much acetylene. You want the acetylene flame long and tapered and just feathering at the end before adding oxygen.
Next depress the oxygen lever to add cutting oxygen and observe the center flame cone. It should be very long and very uniform to the end of the flame cone. If not reclean the oxygen orifice. A dirty cutting orifice will have the end of the flame cone belled and or ragged. This one is very important as it makes the cut very smooth and slag free, well almost! The speed at which forward movement of the cutting also has to do with slag and slightly with cut smoothness. But if you ever seen the guys that can cut smooth as paper, they have the center hole very clean and uniform. This is the seceret to making a very smooth cut. Proper speed and steadyness will come with experience.
Metal warp while cutting solid material comes from too much preheat flame. Most of the over heat starts with a dirty tip and the troch flame not set correctly. A clean cutting tip takes less heat to make the same cut thus no warpage.
T_Bone
Gregg
03-02-2002 04:43:24
 Re: Re: Cutting Torch Question in reply to T_Bone, 02-27-2002 01:38:01
Great review on the basics. I haven't used my torch outfit for some years. What PSI do I start out with for the OXY and Acetylene? I'm planning on cutting a few holes in angle iron for a new trailer. All the info has already been very helpful.
Mr. Weld(TX)
03-08-2002 09:44:18
 Re: Re: Re: Cutting Torch Question in reply to Gregg, 03-02-2002 04:43:24
Gregg, If you are going to be cutting general purpose steel (1/8"-3/8"), and your hoses are 10-20'long, the suggested psi for the oxygen should be at 20 and the acetylene at 5psi.
T_Bone
03-02-2002 10:28:03
Hi Gregg,
I use two settings for all my cutting and brazing.
Cutting 40oxy/5acetylene
Brazing 20oxy/5acetylene
Acetylene is set with gas flow on at the mixing chamber and gives about 7psi at the regulator when shut off.
I control all final pressures with the mixing chamber. The reason for the above pressure settings is on the job with a 100ft of hose stretched out I never had to readjust my regulators.
You might want to do a search on this forum as cutting/brazing has been talked about alot this past couple months.
Glad we could help.
T_Bone
Mark Kw
02-27-2002 06:00:57
Only thing I'll to T_Bone's excellent reply is that I also lay the angle with the legs facing down. I start my cut in the web by pre-heating enough to allow for instant pierce penetration of the web. Then cut from the center to one side and return to the center again and cut to the other side. I use LP for fuel gas, which on angle to 3" x 3" x 3/8", I can lay the torch on the center and cut to each side by simply rotating the torch head to that side. Makes for nice strait cuts since you don't need to move the torch head from the center of the work piece to complete the cut. Also, very little slag using this method as it is all directed away from the work. This does not work well with acet fuel gas since you will loose the cut once the kurf exceeds about 3/4" from the torch tip. On small light angle, you may find it will work well.
T_Bone
02-27-2002 13:18:51
 Re: Re: Re: Cutting Torch Question in reply to Mark Kw, 02-27-2002 06:00:57
Hi Mark
I must have been too tired to get my point accross as you said it really easy....lol legs facing down
good point about tipping the cutting head.
T_Bone
Mark Kw
02-28-2002 05:50:45
 Re: Re: Re: Re: Cutting Torch Question in reply to T_Bone, 02-27-2002 13:18:51
I knew what you meant the first time. Having cut tons of angle in the field, you get to find the fastest and easiest way to make clean and strait cuts.
