Tree clearing, havroc saw, chipper help needed!
Scott
02-20-2002 14:06:58
I have 80 acres of dense, small (3-8") pecan trees that I am clearing to make the other larger trees productive. I have not found an economical and quick method to get these trees out.
I currently cut most with a chain saw and burn, but I am leaning towards getting a large chipper (Bear Cat) and possibly a Havroc saw. The saw is like a "V" that you drive forward and next to the tree to cut at ground level.
PLEASE give me some opinions and your experiences with this type of equipment.
Scott
02-22-2002 08:56:51
 Re: tree clearing, havroc saw, chipper help needed! in reply to Scott, 02-20-2002 14:06:58
Thanks for the replies.
My three priorities are speed of removing them, making use of as much of the trees as possible (firewood and chips/mulch for about 100 young trees that I am planting/grafting - instead of just burning everything), and lastly: as little damage to wildlife and the wet bottom-land as possible during the tree removal.
I have access to a tree sheer but it takes a few minutes to move and position the tractor and then clip each tree, and there hundreds of small trees each acre. Most (smaller ones) I could almost do as quickly with an ax, and a lot quicker with a chainsaw but not as close to the ground.
Unfortunately there is no good solution. Every method seems to have good and bad points.
It's a shame to let all the good pecan wood go to waste. A few of the non-productive 70+ year old trees are being frilled to let die in place. (I've got hundreds of them.) Seems a waste, but they are just too big manage and too close to good trees to try to drop them while alive. In the Tulsa area there are so many pacan trees that the demand is just not very high for the wood except as good firewood, and even that is a buyer's market this year.
KURT
02-22-2002 08:20:14
Put an add in the local paper and people will come in and take those trees from ya, if they are cut up in 6-8 foot lengths, then you wouldnt have to chip em up.
John A.
02-21-2002 18:41:04
Scott, Ditto, on Big Jakes thoughts on the use
of a Bobcat /a tree sheer. In my country here in central Texas / Cedar,mesquite, elms,oaks,and more junk that grows than you can count, it is
the fastest, and best way to go! But don't burn that pecan! Cut it up in to B-B-Q wood. Shurly there is some BBQ joint that will pay for good seasones wood. Can off set the cost of renting the machine.
PS. A good hand on a machine like this should
be able to clear + - 10 acers/day
My $.02 John A.
Steve Smith
02-21-2002 15:27:30
I have been in tree business for years. We used a chemicial called Torden. You paint the stump right after cutting down the bushes or trees. I use an old paint brush in a coffee can. I cut down an willow about 3 foot dia. and painted stump. Nothing grew back. Most farm stores carry this. Good Luick
Steve Smith
Portland, Me
T_Bone
02-21-2002 17:57:46
 Re: Re: tree clearing, havroc saw, chipper help needed! in reply to Steve Smith, 02-21-2002 15:27:30
Hi Steve,
does it rot the stump or just keep it from growing?
A 3ft willow? And I thought things were bigger in Texas... LOL no I'm in Phoenix
T_Bone
Big Jake
02-22-2002 05:56:10
 Re: Re: Re: tree clearing, havroc saw, chipper help needed! in reply to T_Bone, 02-21-2002 17:57:46
Tordon is a herbicde. Certain trees such as hedge & locust will grow back, usually thicker
& bushier after being cut down unless you spray a herbicide on them.
Big Jake
02-21-2002 06:02:52
I prefer a tree shear mounted on a skid steer. Then you mount a grapple fork on the skid steer
to pile up the cut trees.
