First off, I should clarify some things. Harris is part of Lincoln Electric. For as much as I favor the Harris torches because of their lasting value and dependability, I hate the Lincoln weldering machines. So the only "selling" I do is of the services of MY business services. When a company has a good product that is worthy of plugging, I'll plug it for what it is. Likewise, if the same company has a product that stinks, I'll also say so. Now, back to the point. Way back when, I used only acet torches for everything just like everyone else. I have a nice Victor set I used then and tried the LP tip on it. The performance was less than desired and I went back to using acet. A year or so later, I was working a job with a guy who was using the Harris type F torch with LP. I asked why and he said, "here, give it a try...this is how you set the flame...this is how you work it...and so forth." I was very impressed with it but never followed up on it. A few months later, a friend gave me a harris type F because he only used acet as well. I decided to try it for myself. It did take a while to get used to it and find all the little tricks you can do with LP you can't do with acet. Having used LP for years now, picking up an acet torch for cutting is like working with Fred Flinstone and Barney Rubble. I'm not here to "sell" anyone on LP or Harris. I speak my piece in a manner as "if you are serious about using LP, then here is what you need to get, do, ect." I have a large acet cylinder in my shop right now. Matter of fact, it's the same one that has been here for about 6 years because it sees very little use. I don't recall even putting a regulator on it in over three years. One day I had a small brazing job to do. Nothing special, just putting a few carbide tips on a cutter for my milling machine. I did not feel like wasting time un-packing and hooking up the acet torches for this small job so I grabbed for the Harris already hooked to the LP. A few practice runs later I brazed the tips on and went back to work on the money making project. Since then, I have used the LP for all the occasional brazing jobs as well as silver soldering. Cast iron is done with stick electrodes. Stainless is done with TIG, MIG or stick. Alum is done with MIG or TIG. Thus there is little need for acet at all for me. I have looked into using a spray torch for build-up work but the little bit I do and the applications, the cost does not justify the need. The few build-up jobs I do are done mostly with short circuit or spray MIG because it is fast and much more cost effective. I said before, I have not even attempted to weld with LP because I have no need for it. I invested around $60,000 in welding machines for that purpose. Granted the average DIY'er is not about to consider dropping $20K for an Areowave just to have laying around for the occasional tig job on alum. This is how I make my living and is why I need to use the fastest and most cost effective means to get the work done. For me to waste a couple hours doing a weld joint with torch is insane considering I could do the same weld with one of the electric machines in a couple minutes. I can probably count on one hand the number of braze jobs I did last year and using both hands cover the number of silver solder jobs. The plasma cutter does all the shop cutting to 1.25" thick like butter and faster than the torch so why bother lighting up a flame when I can pull a trigger? For the DIY'er who is looking for an all around tool that will do welding as well, then acet is the best choice because time is not a concern. The majority of my cutting is what most would consider "heavy duty". The way one looks at things is directly porportional to what they see every day. I look at a 100,000 excavator and to me it's not much more than a Tonka toy yet to someone else, it is a "giant" machine. In the same note, my working with steel in excess of 1" thick is common place. The other apsect is that when someone who does not do this for a living looks at a welding job, they size it up in number of rods, I size it up in pounds of weld laid down. Time is money for me and I can't waste time playing with toys or I don't eat. This is why I like LP and a Harris type F for cutting. It's faster and cleaner than any acet torch made by anyone. You want "proof" of this, you're welcome to come and watch me work all you want. I'm not looking to stir the pot here or say that LP can replace acet for everything but it works fine for brazing and soldering and cuts faster. It may not be the best choice for everyone or every application and I don't want this to sound that way. For me, LP works better and faster than anything else and is far more cost effective all around. On rusted, crapped up steel or nice clean new steel, you don't stand a chance keeping up with the cutting speed of LP.
