Attention Steve US Alloys
llamas
02-19-2002 06:54:28
Steve - got a question for you. It comes from the N-board, but apparently they're all too shy to come on over here and ask you themselves.
It has to do with the oil pickup assembly on the Ford N motor. The oil pump on that motor is built into the front main bearing shell, which is a steel forging of some sort. The oil pickup tube is a drawn steel tube, maybe 3/8 or 1/2 in diameter, which is attached to the pump housing.
The attachment is a known weakness of this design. The pickup tube hangs out sideways, it's - oh, maybe 6 or 8 inches long, and it has a drawn bell on the outer end which hangs inside a creen cup to pick up the oil. The tube is set into a socket in the pump housing where it is - attached by some metal-melting means, and that is the question. Sometimes the tube itself cracks around about the point where it enters the housing, but sometimes the melted-metal attachment lets go.
Conventional wisdom is that this joint is made by brazing or silver-soldering, and those terms (as you know) mean different things to different people. Myself, I doubt that it is "brazed", because to me that implies an oxy-acetylene torch. It might be "copper-brazed". It may well be attached using some higher-melting-point solder. Some think that a conventional, plumbing-style tin-lead solder would be enough to do this job.
Drawing on your vast store of knowledge in this area - what would you suggest would be the best attachment method? That a guy could do himself, if he bought the materials from you? And what size rolls does it come in?
Any input you have would be useful.
Have a great day,
llater,
llamas
Pat Woodruff
02-19-2002 18:41:15
 Re: Attention Steve US Alloys in reply to llamas, 02-19-2002 06:54:28
Steve,
I have the "broken" oil pickup tube that led to llamas posting the mesaage here to you. Where do I go get the 1216 to repair this?
Thanks
Pat
Steve U.S. Alloys
02-20-2002 16:49:52
 Re: Re: Attention Steve US Alloys in reply to Pat Woodruff, 02-19-2002 18:41:15
They have a toll free number for ordering, Pat. It's 1-800-325-1568. You can read more about that solder on the web if you like. I'll include a link.
Steve U.S. Alloys
02-19-2002 18:24:29
Thank you for the compliment Mr. Bakker, that means something coming from a gentleman of your caliber.
If I'm picturing this thing correctly, it would seem that the root cause of failure is most likely to be contributed to vibration. A cu based alloy does not typically lend itself well to that type of stress.
I would think a relatively high grade,low temp, soft solder would be useful here. If I were recommending something in our line it would be the #1216 with an acid core. It has good flow and creep characteristics and good shear strength as well. It does actually contain a small percentage of Ag as well. Bond temp is 430�F and the alloy is available on 1# spools in diameters of 1/16"-3/32" & 1/8".
This part may have originally been placed using a higher heat process. That could have contributed to the failure of the tubing (due to vibration)in the HAZ where the carbides would concentrate.
I wonder if a threaded tube with Loctite applied might also be a good fix. Just a thought.
Steve
