Need someone with hydraulic catalogs
teadave
02-18-2002 19:57:40
i have been given a hydraulic pump and a valve i would like to use. i am looking for the specs on these and can't find them on the net.
hopefully someone can help me out or steer me in the right direction.
pump:mfd by commercial shearing
model-p50a242 beam 22-7
ser#-688474
valve:mfd by koehring(husco division)
it has the following #s on it
k787082
20-28741
4403-22c
if it helps at all, these came off of a garbage packer of unknown make.
thanks for any and all help
rhudson
02-22-2002 05:57:07
 Re: need someone with hydraulic catalogs in reply to teadave, 02-18-2002 19:57:40
Hi Teadave,
The Baum Number is 800-228-9288 or www.baumhydraulics.com
I have not had a chance to try to look up the valve, but will try this weekend. is the valve electrically shifted?
teadave
02-22-2002 14:15:58
 Re: Re: need someone with hydraulic catalogs in reply to rhudson, 02-22-2002 05:57:07
nope. its either 3 or 4 spool-really weird configuration- and its manually shifted
rhudson
02-22-2002 20:13:16
 Re: Re: Re: need someone with hydraulic catalogs in reply to teadave, 02-22-2002 14:15:58
ok, if it four position and in one of the positions both piston and rod side of the cylinder are tied to pump? thats regeneration, used for rapid extension of the cylinder when their is little material in the bailing chamber. anyway if i can free up a little time, i'll try to find the valve info. what type of compactor was it? Name brand?
