Treadle lathe spindle
Bill McIlwain
02-16-2002 11:19:22
I'm building a foot-powered lathe for wood turning. I need a drive spindle 1" or so in diameter, 8 to 10 inches in length, with a #2 Morse Taper. Where I could find one or how could I improvise a spindle that would hold a drive center of some sort?
Greg
02-21-2002 04:32:23
 Re: treadle lathe spindle in reply to Bill McIlwain, 02-16-2002 11:19:22
Wow, I am planning on doing something similar and have been collecting parts. My wood lathe I am building will be powered by a motor though. What I found for the spindle is a Collis rough socket. Part # 60902 Morse taper #2 8 inches long. The diameter is stepped one end 1.25" and the other end is 1". Part # 60903 Morse taper #3 10 inches long. Diameter one end 1.5"; other end 1.375". You can see the Collis catalog at>Link
You can order the roughing sockets from MSC 1-800-645-7270 or Blue Ash Industrial supply 1-800-624-5050.
If you find anything better, please post the information.
Hope this helps.
Greg
02-21-2002 04:34:19
 Re: Re: treadle lathe spindle in reply to Greg, 02-21-2002 04:32:23
Link to MSCdirect catalog page on Collis roughing socket
snitkawl
02-17-2002 05:10:10
WW Grainger has Morse taper adapters of about every type. You could check with them to see if there is anything you could make work. They have a website, so you could check on line. Good luck, sound like an interesting project.
Kraig WY
02-16-2002 16:46:17
Any machine tool outlet has them. If you can't find one go to a machine shop and get a worn out 1 in. drill bit with a #2 mt. and make one.
