Any Experience On Re-riviting Wheels?
TMAC
02-15-2002 17:31:13
I am going to remove bad rims and flat spokes on cut-off wheels from a F30. I will be using nuts and bolts to connect the spokes to the hub but I eventually want to replace them with original looking rivits(not spelled right,is it?) Is there a certain way or tool needed to do this?
Redtractorman
02-16-2002 18:33:08
 Re: Any Experience On Re-riviting Wheels? in reply to TMAC, 02-15-2002 17:31:13
I took the brackets off an Avery A wheel that was shot and put them on a Farmall BN wheel using rivets and it looks original.I bought the right diameter rivet and cut them off to the lenght I wanted(about 2 1/2 times the width of the material being fastened together)Then you put them in hole and peen so they are still loose but will not fall out.Heat with a torch until cherry red them penn them down,alternating between the 4 rivets that hold on bracket,keep them all hot until they will not peen down any more and when they cool they draw up tighter.
Franz
02-15-2002 22:00:23
The easiest way to set rivets it with a rivet setting "chisel" in a Parker 401 size air hammer.
As you remove the rivets, check to see if the holes the rivets are in are straight or tapered. Tapered would indicate the rivets were originally installed hot.
The chisels are available from SnapOn, and probably Graingers as well.
