Why is my trailer suddenly so bouncy ?
D. Thomas
02-10-2002 16:15:18
I've got a fairly new Anderson "6 ton" flat bed open trailer with dual axles and 4 electric brakes. I hauled an old Baker forklift last week on it that weighed near it's limit of 5 tons (6 tons includes the 1 ton weight of the trailer itself) and ever since then the trailer has been much more "bouncy" than it was, with nothing on it or with a moderate weight (such as 3,000 lbs) on it. It's bad enough that it's quite unpleasant to use now. I suspected a broken leaf spring support weld but I've looked twice and see no evidence of this...everything looks fine, no evidence of broken structural welds either, no evidence of anything bent. Any ideas on what might be wrong with this trailer ?
(btw, it doesn't help matters that I'm now hauling it with a half ton truck rather than the my previous one ton truck, but the trailer felt fine with the half ton until this forklift hauling incident. I did ponder the possiblity that there is nothing wrong with the trailer and the incident may have somehow "broken" the shock absorbers in the truck, but since then I've hauled 1,000 pounds in the back of the truck 200 miles and it felt fine. Still, I wonder....)
trader
02-13-2002 19:15:16
 Re: Why is my trailer suddenly so bouncy ? in reply to D. Thomas, 02-10-2002 16:15:18
You may have a bent axle that you cant see with your eye. You mentioned in one post that it fish tailed some and you attributed it to weight being too far back. Maybe it was a different reason. I have seen empty trailers go airborn from one side of the road to the other from a missaligned or bent axle. Try measuring from your ball to each axle at the same point on each and see if both front have same measurment and then repeat for rear. They need to be within an 1/8". Also jack up trailer and spin the wheels to see how true they run. Maybe put a fixed object up close to them and measure runout as you turn the tire. A lot of trailers these days come with cheap tires AND wheels. You could have a bent one. and obviously check the tires as everyone else suggested.
D. Thomas
02-13-2002 19:29:06
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to trader, 02-13-2002 19:15:16
Just for the record, I did not say it fishtailed...I said that it probably would have (based on experience with other trailers I've owned) if I went highways speeds or down steep hills, but I didn't, so it didn't. Good idea on the axle measurments...I'll do that if the tires check out ok.
T_Bone
02-12-2002 18:35:14
Hi DThomas,
When I was young and dumb I bought a green unit of 2x4x 96" about 3800lbs and put them in the bed of my 3/4 ton power wagon 6000lbs, then loaded two units of green 2x4x16ft about 9000lbs on a 20ft flatbed about 4000lbs hooked on and away I went with 22,800 gross.
My hitch tongue was 1/2" SS 4" drop hitch on a custom built 2" receiver with a 2"x1" ball.
When I had the guy set the 16ft'ers on, the truck squated a tad so I had him move'm back about 6".
I proceeded to the interstate and got on the ramp at 20mph and just as I hit 25mph the trailer took off towards the center guard rail accross 3 lanes. Lucky an experienced 18wheeler seen I was in trouble and gave me lots of room and there was no other traffic. Keep in mind I had no prewarning nor had no control of where I went as I was just along for the ride as the load was in control at this point. I was lucky enough to think to grab the trailer brakes as it was heading back towards the right shoulder of the road and got it slowed down and back under control. I took the next off ramp and went back to the sawmill yard and had him move the load forward 6".
I then headed for home 150 miles away. On the way I keep getting a slight thump and small viberation. I droped the trailer and seen that my 1/2x2-1/2"SS drop hitch has started to tear about 1/2" from one cornner. Gees, I prayed alot to GOD that night.
A new hitch and receiver was born the next day!
A couple days latter I have to go pick-up 4ton of feed and I'm still feeling that small viberation. While waiting for the mill I'm sit-in on another guys tailgate BS'ing and He says whats wrong with your truck tires? We go look and find that I had seperated the cords between the ribs on both rear truck tires. Them Coopers had 60k miles and still looked to have another 60k left on them. Being a full time 4wd I had to replace all four tires.
The trailer axle remains bent to this very day. Now I only use it for short slow trips for my farm on back roads. I never fixed the axle as I wanted a reminder of what not to do and that was 25yrs ago. It balds a tire about every two years or 600 miles.
I thought I'd share this with you so you might have something to think about as all that happened in about 6 seconds.
T_Bone
D. Thomas
02-13-2002 07:03:49
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to T_Bone, 02-12-2002 18:35:14
Good story. Speaking of "praying" situations, I once was driving a 2 ton rollback fully loaded with machine tools, 65 mph down the interstate, when one of the dual rear tires disintegrated. I pulled over and close examination caused me to realize for the first time since I bought the truck (used), that the rear tires were recaps. Naturally there was no spare, the tires were an odd size, and it was of course on a Sunday. So, with 200 more miles to go, I'm now very afraid of the single tire (where there was dual before) also disinterating...in fact it seemed even more likely as it now had to bear twice as much load...which would have been a disaster with all that stuff on the truck. So, I decide to take back roads and stop at every open service station I find looking for a new tire...wasted much time looking but noneone had the right size. Also stopped every few miles to hose down the tire with water to cool it off. After a hundred miles of this finally found the correct tire at a truck stop...paid dearly for it too but gawd, what a relief. Took 8 hours to go that last 200 miles.
Ray,IN
02-12-2002 19:19:38
I agree with T_Bone. Inspect your tires carefully. I had a truck tire tread separate from the cord belts and the tire looked fine. The only time you suspected something was around 40mph when the vibration began, but it quit at 50 so I kept driving. 'Bout 80 miles down the highway the tread flew off,while towing a 30',9K lb, 5th wheel and a semi passing. Then I had to change - a tire and shorts!
Terry-N-Mo
02-12-2002 16:26:18
More than likely its the trailer but have you tryed towing it behind a different vehicle to see if it does the same thing? I`m having the same problem. I`ve checked tires,rims,springs and still haven`t located the problem but mine is just an ole homemade trailer. Terry
D. Thomas
02-12-2002 18:24:06
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to Terry-N-Mo, 02-12-2002 16:26:18
I would like to do that but I my only other vehicle is a Mercury Sable (without a trailer hitch) and seems like most of my friends drive un-trailer hitched vehicles, so can't borrow one either.
Chicken George
02-12-2002 07:21:55
Thomas,
If the trailer seems bouncy could it be that possibly the shackles/mounting bracketts for the springs on the trailer are "binding" maybe something moved or bent. are the springs mutiple leaf that could have come down on the other leaves therefore more "harsh" riding?
seems like you had the trailer loaded to the rear, did a "dogbone" flip or did you get a slight kink in the frame causing a"bind"in the shackle? gotta look close, keep us informed as we are curious Luck!!
llamas
02-11-2002 16:24:57
What follows may be entirely out of place. It is based only on my reading of what you wrote. If I misunderstood your post, then I apologize in advance.
You ask what might be wrong with your truck or your trailer after pulling a 12,000 pound load (your estimate) with a half-ton pickup. You don't say what brand.
Had you considered that the problem might stem from the fact that you're pulling almost 50% more trailer than the absolute maximum that the truck is rated for? If we look at the specs for a Chevy half-ton, for exmaple, we find that the absolute maximum that it will pull is an 8200 pound trailer. That's with a weight-distributing hitch, sway bars and HD trailer suspension package. Ford and Dodge, about the same.
Please don't tell me that you're just hitching this thing up to a receiver hitch - at least let it be a gooseneck. Because if you are, then IMHO your actions change from being merely unwise to being criminally reckless. If it's a gooseneck, you've likley merely grossly overloaded the truck from a hitch weight standpoint. If it's a receiver hitch, you're very lucky that it didn't tear itself off the back of the truck.
Whatever the case, I doubt the problem is in the trailer. I'd be looking very hard at the truck.
Please tell me that I misunderstood what you wrote, and I'll be the first to apologize. But if it is as I describe, my question is not what is wrong with the trailer, or the truck, but what is wrong with you.
llater,
llamas
D. Thomas
02-11-2002 17:07:36
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to llamas, 02-11-2002 16:24:57
Yes, way beyond normal capacity of the truck (which is 7,000 lbs tow cap. as I recall)...but it was fine because--
1. It was only for 3 miles at speeds no greater than 40 mph, trailer has excellent brakes, truck has excellent brake controller. Terrain is flat and rolling starts were easy and gentle. But the most important point is that it was only 3 miles and the terrian is absolutely flat.
2. It was a Toyota Tundra 8 cyl. which pulls with more gusto than my previous GMC 1 ton turbo diesel
3. Not a gooseneck, standard 2 5/16" hitch. Being a rolling load it was easy to fine tune the tongue weight to not overload the truck springs. This of course was not enough tongue weight to prevent fishtailing if I was going at highway speeds or down a steep hill, but I wasn't, so I knew it would be fine...and it was.
If you think the problem is with the truck, what, exactly might the problem be ? As previously stated, I considered that as well, and have closely examined the truck underside...all looks fine. I am still open to the possiblity of a broken shock or such. But it seems pretty unlikely all things considered.
llamas
02-11-2002 18:24:10
 Re: Re: Re: Why is my trailer suddenly so bouncy ? in reply to D. Thomas, 02-11-2002 17:07:36
Well, it doesn't sound as though you did anything inappropriate to the trailer except load it waaay far back to keep the tongue load down to what the truck would stand - I'm guessing 1000# maximum?
That's why I suggest - since it was the truck that you overloaded by some 80%, then that's where you start looking for failures. The fact that you went slow and easy is all very well, but the fact remains that you asked it to do 80% more than the absolute maximum it was designed to do. I don't care how slow and easy you went, at some point, something's got to give. The reaction loads that you're injecting into the hitch, the frame and the suspension all increase directly in proportion to the mass you're pulling and as the square of the speed.
It doesn't matter how much power the truck has to pull the load - what matters is the strength it has to transmit that load to the trailer, and to resist the loads that the trailer sends back to it when braking or turning. A Chevy Cavalier would likely be able to get the trailer moving quite nicely on flat ground - does that make the Cavalier an acceptable tow vehicle?
I can't say what might be wrong but I would still look at the truck first. I suspect something in the alignment of frame, wheels and hitch. Or the hitch may be pointing up or down now, which would explain why you get strange reactions from the trailer but nothing when you're just using the truck. Or you may have moved the back axle rlative to the frame, either by slipping it or distorting the frame mounts.
I had a man come and dig me some footings this summer. He brought a midsize New Holland skidsteer with the backhoe attachment, about 14,000#, on a twin axle trailer much as you describe, pulling it with a Chevy 3500 dually. He was pulling it off a pintle hitch inserted into a receiver, much as you describe. The receiver was marked as being a 10,000# unit, aftermarket - Chevy doesn't rate this ride to pull 10,000 off any sort of straight receiver, only off a load-distributor, fifth wheel or gooseneck.
All was well until he had it loaded up to go. He put the truck in gear, pulled away smoothly and there was an All-Mighty Bang from the rear of the truck as the whole trailer rig sagged down until the jack hit the ground. One side of the receiver assembly had sheared off clean, the other side was starting to tear out as it tried to carry the entire load.
Took an hour of jacking and cribbing just to get it picked up enough to unhook the remains of the receiver from the pintle eye. Scary as all get-out, and he did the trailer no good at all getting the skidsteer off it with nothing to hold the front end down.
If'n he'd gotten a mile down the road with it, it would have killed someone when it let go, no way in the world you could keep something like that under control.
Despite what you say about this being "fine", I have to repeat my opinion that what you did was reckless in the extreme, certainly illegal, and shows a cavalier disregard for other road users which I find very difficult to stomach.
llater,
llamas
D. Thomas
02-11-2002 20:42:06
 Re: Re: Re: Re: Why is my trailer suddenly so bouncy ? in reply to llamas, 02-11-2002 18:24:10
llamas, I've done tens of thousands of miles of towing heaving loads over a couple of decades, without a single accident or even come close to an accident. I did have one vehicle failure many years ago, which probably involved towing 14,000 lbs via gooseneck trailer and a half ton Jeep J10 pickup. This extreme involved 600 miles of interstate driving with some low hills and eventually resulted in the need for new rear end gearing in the Jeep (however the vehicle was not known for it's reliablity and might have needed one anyway for all I know). You failed to mention the main danger of overloading a half ton truck, which is the possibility of an axle/wheel of the truck actually disconnecting from the drive train and flying out of the case...a situation that is not possible on 3/4 and 1 ton trucks due to different design. So you see I'm well aware of the limits of half ton pickup trucks. Your story of the contractor loosing his receiver assembly is interesting but meaningless without knowing if it was bolted properly to the truck frame, with proper grade bolts, which I suspect it wasn't. Regarding something having to give "at some point" I agree, just think it highly unlikely that "point" would occur after a mere 3 miles of slow flat travel. I wouldn't disagree with your last sentence if my incident involved highway travel, but I repeat...*3 miles* of *flat*, in town travel using an almost new truck, almost new trailer, within it's capacity, with excellent brakes, emergency breakaway braking device, and with an experienced in towing person at the wheel. And most of the 3 miles involved just going a couple of blocks at 20 to 30 mph, stopping at a stop light, going a bit more, etc. I've towed a 6,500 lb boat with a Jeep Grand Wagoneer, which is within rated capacity of the 8 cyl Wagoneer...but can say that that combination was much more "scary" than this piddly little trip with it's much superior tow vehicle (the Tundra) If, given these facts, you persist in the "reckless in the extreme" description, then I can only conclude you are an alarmist in the extreme and don't know what the heck you're talking about.
cd
02-14-2002 15:58:34
 Re: Re: Re: Re: Re: Why is my trailer suddenly so bouncy ? in reply to D. Thomas, 02-11-2002 20:42:06
i dont see a problem with what you were hauling, it was just something freak that happened, on or 2000 F350 Powerstroke 6spd we have hauled 20,000 and the guy before us hauled more than that on the 18k Moritz trailer, we had an 86 F250 6.9L pulling over 18k on the trailer for a few miles one day. i believe than other than some exceptions, if you can stop it then its ok as long as it seems safe, that guys reciever ripping off was his fault because good mounted recieves just dont rip off.
llamas
02-12-2002 03:41:15
The contractor's receiver did not fall off the truck. The left side plate of the receiver assembly itself broke in half. The bolts holding the remains were tight, and right. I know - I helped him remove the remains so he could drive the truck home. Your comment about "which I suspect it wasn't" indicates that you are quite happy to pass judgements on situations you know nothing about.
You're obviously aware of the limits of half-ton pickups - it's just that you decide that they don't apply to you. What can I say? Why do you suppose that Toyota defined the towing limit as they did? You think they might know a little more about the structural limitations of their design - than you do?
I have plenty of towing experience as well as semi-truck experience. Suffice it to say that if a semi-truck were stopped with a 71.4% overload, the driver's going to jail, and you would be crying for his blood. What exempts you from operating within the limits of your equipment?
Your accident-free experience does you credit, but that simply says you're a good driver. I don't care how good a driver you are if the equipment fails you due to gross, unpardonable overloading.
You towed 14,000# with a half-ton pickup? Your exuberant over-confidence in the margins of the truck is wonderful to behold. But, given that story, I stand behind my comment - reckless in the extreme. You haven't had a wreck yet? It's only a matter of time, if you consider it perfectly acceptable to overload in this way, and then scratch your head and wonder what you might have broken doing it.
Have a nice life. I just hope you don't drive in my neck of the woods.
llater,
llamas
D. Thomas
02-12-2002 05:27:15
 Re: Re: Re: Re: Re: Re: Why is my trailer suddenly so bouncy ? in reply to llamas, 02-12-2002 03:41:15
Re your contractor's receiver assembly, all I can say is there must have been either rust or a manufacturing defect involved. A properly made hitch hooked properly to the truck would not fail during a gentle attempt (i.e. not a running start then jerk motion) even if the truck hitch was chained to the Rock of Gibralter...the truck just simply wouldn't go anywhere, even in granny gear and 4WD.
Re the 14,000 lb towing incident, that was 20 years ago, and I'd never do it again...not because it was dangerous (here again, well within limits of the trailer, excellent brakes, gooseneck trailer, pickup had overload springs, etc.) but because it probably did damage the Jeeps rear end gears, and it was slow go on the hills. And there was that small possiblity of axle throwout I mentioned earlier.
Just to ease your mind, that incident and this latest one's are the only towing incidents in memory where I was officially overloaded. I'm not "bragging" about it and don't recommend it, but sometimes a person has got to do what ya got to do to put bread on the table.
I've since talked to the trailer dealer and the manufacturer on the phone, and they agree the culprit is most likely a trailer tire defect. Will let ya'll know the results of a "Dr. Tire" analysis soon.1
Steven@nd
02-11-2002 12:32:54
I would check the tires first. Has happened to us on lots of vehicles and trailers, brand new tires can have a separation internally that makes them so that they will not balance. Had a set that would only balance until you hit 80 mph then they would shift a belt again.
Tires, then wheels, then axles/bearings, then springs.
Steven
Stephen
02-10-2002 22:10:42
I'm in agreement with the others. If I were you, I would just take it down to the local tire place and have the tires checked for proper balance. Take it to the place where you bought it and see if they can do it. It is not uncommon for new tires to come apart inside.
I've experienced your delima with a trailer of mine, and it turned out to be a sepration in the cords. I also experienced it with a Ford Thunderbird that I had bought with only 12,000 miles on the car, and when I would brake the steering wheel would shake mildly. I just attributed this to a slightly bent brake rotor. Boy was I wrong!! Turns out, when I went to have new tires put on at 38,000 miles, from "visible" wear, that when the tires were inspected after being taken off, one of the front tires was about ready to shread on me. It was coming apart inside. It was stupid of me to wait so long to just go in and have it checked. Anyway, after I put the new tires on, it doesn't shake at all anymore, who knows what damage I might have caused to other parts on the car for my waiting so long.
Anyway, just because anything you buy new, may be new, doesn't mean it won't have problems. There might have been problems with the batch in the factory.
Stephen
shoe
02-10-2002 20:58:37
I might be wrong, but it sure sounds like one of the four tires has separated. Don't know what else it would be. Hope you get it figured out, something like that can drive a guy crazy until
you find the problem.
shoe
02-10-2002 21:14:05
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to shoe, 02-10-2002 20:58:37
Most of the time if a tire separates you can see
it visualy. I have had almost new tires separate,
was a factory defect I guess. If that's the problem you should be able to see a bulge on it.
D. Thomas
02-10-2002 21:07:12
I haven't inspected the tires real carefully but just to look at them they look fine...they are only 6 months old and maybe 1,000 miles use. Can they be defective and yet look ok ?
chris
02-10-2002 19:01:36
did you happen to adjust tire pressure
D. Thomas
02-10-2002 19:24:16
 Re: Re: Why is my trailer suddenly so bouncy ? in reply to chris, 02-10-2002 19:01:36
Nope
Richard
02-14-2002 17:01:00
 Re: Re: Re: Why is my trailer suddenly so bouncy ? in reply to D. Thomas, 02-10-2002 19:24:16
Take a look at the springs, bounce on the trailer and make sure that the springs are moving. Sometimes people tighten the bolts too tight in the shackles thus not allowing the springs to spring back. After a Heavy load, they could be slightly compresses or 1 axle may not be even with the other as far as spring load.
And.... what the others said. No guarantee but very simple to check.
Jerry B
02-10-2002 17:51:27
I would suspect a tire or rim. Perhaps a tire has had a belt to shift and cause the tire to go out of round considerabley. Maybe a wheel has become bent and causing the the tire to wobble and this is what is feeling like a bounce.
