Hi Jim, Yes take your overall length, and the above rule works on any number of axles on a flated, upto a tri-axle on a beaver tail with the 2/3 being the center line of the middle axle. example; 24ft trailer tandum axle, 15.98ft from the center of ball/pin to the center inbetween the two axles. On a flatbed that will give the correct "empty" tongue weight with loaded tongue weight adjusted with the load weight moved forward or aft to make weight. If building a fixed load trailer, like an RV, then the inside load weight would be distributed over the number of total axles. On a tri-axle then it would be 15.98ft to the center of the middle axle. Example; on a 32ft flatbed tandum it would be 21.31ft from the center of ball/pin to the center inbetween the two axles. on a tri-axle it would be 21.31ft to the center of the middle axle. The 2/3 rule comes from the Bible so it's tried and true "rule" and can be applied to any design. A cross is placed at 2/3 of it's length and 1/3 of it's length is also it's width of the cross. A round tank base diameter is 1/3 of the height of the tank. Square tanks will go oval when filled, it's liquid filled balance point! A boat beam width is 1/3 of it's length. A building square base is 1/3 minmium of the total building height. etc; T_Bone
