Well, folks, here is another progress report on the engine replacement and operation: Today, I drained the oil+Sea Foam mixture from the engine after two days of letting it sit there. The oil coming out was actually nice and clean. So, I guess it is a good sign! I put in fresh oil, hoocked back the muffler, charged and connected the battery. Then I took the spark plug out and gave the engine a few quick cranks. A lot of clear fluid came out of the spark plug hole. It maybe just gas or some of that SF I put in couple of days ago. I clean the spark plug and put it in. I cranked the engine several times again. The engine turned smoothly and a couple of times even the muffler back fired with smoke (good news or bad news?). The engine never actually started. Just turns ok with a lot of compression. When I take the spark plug out, it is full of fluid and dripping wet. When I crank without the plug, a lot of fluid (gas?) comes out of the hole. We have spark, we have fuel (maybe too much of it), and the engine turns ok, but not starting. Obviously, the wet spark plug is not helping. But the question is why does it keep being wet? Is it a carburetor problem? From what I have described here, does the engine seems ok? And what to do next? You folks have been with me all along, and I appreciate it. Now, let's get the engine going. Thanks, James.
