Parts for a Sears Snow Blower Model 536.918100
Bill
02-04-2002 14:40:08
I have a Sears snow blower and Sears no longer stocks parts for this particular model. I need the gear that goes on the auger shaft. If anyone knows of a source or has one, please let me know.
Thanks..
Bill
MJ Mayotte
10-28-2006 11:36:58
 Re: Parts for a Sears Snow Blower Model 536.918100 in reply to Bill, 02-04-2002 14:40:08
I wish I had read your comments before I just bought a used Model 536.918100. It seems to work just fine, but it does leak a bit of gas after being used. The previous owner, who refurbishes snowblowers and sells them, said that this is common with this model and that it starts leaking after you turn it off, but it soon stops. Have you had any leaking issues? It is leaking right under the rear fram assembly under the carburator. Also, do you know where I might be able to get a copy of a manual?
Mark
Joe Newman
02-16-2007 07:34:26
 Re: Parts for a Sears Snow Blower Model 536.918100 in reply to MJ Mayotte, 10-28-2006 11:36:58
Mark: Did you ever find a copy of the owners manual for your old sears snow blower? I'm also looking for the book..Please let me know...thanks
tom hebzynski
03-08-2006 14:07:26
same snowblower, need a carburetor for it. tecumsh
ISRAEL
01-21-2005 09:26:54
I AM LOOKING FOR PART # 50223, THE GEAR WORM
Mac
02-06-2002 11:32:32
Bill: I looked at that number. Crossed it and it sez these were made by AMF (murray) I didnt look but thinks they have a web site. Maybe worth a try.
jim
02-05-2002 23:04:47
just tonite i through out sears 8" 1 hp bench grinder. industrial model supposedly. parts not available. no more sears power tools for me unless they are throw away.
Ron Bair
02-11-2005 12:17:23
 Re: Re: Parts for a Sears Snow Blower Model 536.91 in reply to jim, 02-05-2002 23:04:47
I'm glad I'm not the only poor smuck looking for the same part.
But here may be a solution. My Sears blower is a 22 inch 5 hp the worm gear 50223 went to gear heaven. Murray has suck all the models up.
They have the same gear but different tooth count
So I pulled the Murray blower model 62250x4a, if you use Murrays gear you would need to replace auger shaft also.
I'm looking at both parts diagrams Sears/Murray and they look pretty close. But this is just a theory. I have a call into Murray for the dimensions on the shaft. But if you are interested the part #s are
for the worm gear 51405 and the shaft is 1501128.
This all happen because The OEM used regular #2 bolts and not shear pins on the augers. Hope this helps.I still have hope.
