Oxy/acet regulators... are they interchangeable?
john_t
01-29-2002 12:33:05
My acetylene regulator is malfunctioning. The best I can describe it is that it "hiccups" at a rate of about once per second, which causes the flame to surge. I have a spare oxygen regulator. So my question is this: can I run acetylene through an oxygen regulator? I realise I will have to change the inlet connector and gauge. TIA, John
caseman-d
02-03-2002 07:47:55
 Re: oxy/acet regulators... are they interchangeable? in reply to john_t, 01-29-2002 12:33:05
John where do you live??? I have to agree with Val on the safety issue on this. Check out some safety films on what happens to people when they don't operate equipment right. A new reulator is small price to pay for your life or someone elses. Just like piece of equipment, learn how to operate it correctly before using it. Hope you get it fixed before you blow yourself up or your family. Thats why I wanted to know where you live so I can stay far away.I don't think Val come across to hard, as I have seen films of what can happen. Good luck with it and hope your around to reply to this.>>>>caseman-d
John_t
02-03-2002 17:04:50
 Re: Re: oxy/acet regulators... are they interchangeable? in reply to caseman-d, 02-03-2002 07:47:55
FOR CRYING OUT LOUD!!! I asked the question because I DO value safety, and safety comes from knowledge. I don't really care about past law suits or how far away from me some of you may have to live in order to feel safe. I value the knowledge on these discussion boards and have even imparted some of my own from time to time. I thank those of you who offered helpful and courteous information without being self-righteous and condescending. Maybe next time you'll have a concern that I can help with.
..... john
Val
02-03-2002 10:07:38
Caseman,
Thanks for the support on this topic. In our business we have made numerous changes to our product to try and protect the user. The most common causes of accidents and deaths with oxy/fuel welding equipment are transporting the tanks by laying them down and not anchoring them, using the torch near flammables, and trying to push the equipment beyond the designed capabilities. Our company has been sued by families of victims welding gas tanks with gasoline dripping from them among others.
Yes, the oxygen regulator will work, but is totally unsafe because it will allow you to go beyond the safe pressure of 15 psi. Regulators are built such that maximum safe pressure is all that you can achieve with the adjusting screw turned all the way in. I guess I've carried on long enough. Sorry. Let's all stay safe and enjoy our hobbies.
Trucker
02-01-2002 21:36:29
Well I read all of those answers,and I think you can use an oxygen regulator for acetalene if you change gauges.I've lain an acetalene bottle on its side and used it too,and unless you go past 15 pounds on the regulator I dont see why it wont work.I might be way wrong,but just because somebody says it wont work doesnt mean its true.To be safe I would ask the man I get my tanks from,and if he sounded like these guys I think I might ask somebody else,like the people who make regulators.As far as I know the important thing is the 15 pounds,just my opinion.
tim, ohio
01-31-2002 09:12:31
John,
One thing nobody talked about is the cause of your problem. Correct me if I am wrong, but one cause could be the way you have used that
regulator in the past. Regulators
of all types can be damaged if they
are not at zero pressure when the cylinder
main valve is opened. If the regulator is
always set at say 5lbs of pressure when
you open the cylinder it can, over time,
damage the regulator diaphram. The correct
way to treat your new one is to always
make sure it is dialed down to zero pressure before opening the main valve.
After the cylinder valve is open, dial
up to the pressure you desire (below 15lb
for acetylene).
Best Regards,
Tim, Ohio
Val
01-30-2002 10:11:48
I'm impressed with the knowledge of those responding. You are right on. I am a mfg. eng. for a oxy/fuel gas welding manufacturer. You would not believe the law suits we get caught up in because of people miss using equipment such as was suggested. USE THE EQUIPMENT FOR IT'S INTENDED PURPOSE ONLY!!!!! By doing that we will all be around alot longer to enjoy our old machines.
bobby
01-30-2002 16:48:59
 Re: Re: oxy/acet regulators... are they interchangeable? in reply to Val, 01-30-2002 10:11:48
lighten up Val,the guy just asked a question.
you make him sound like a criminal. We are all here to learn.
Val
01-31-2002 05:01:31
 Re: Re: Re: oxy/acet regulators... are they interchangeable? in reply to bobby, 01-30-2002 16:48:59
Sorry if I came across that hard. When it comes to safety, I get pretty excited. Have seen some nasty things happen to people who thought they'd try something and find out what happens. Thanks for keeping me in check.
Matt
01-30-2002 03:29:34
No!
Mike
01-30-2002 00:11:40
That hiccup might be something else. If you use an acet. bottle on it's side or you exceed the draw rate for your bottle, you will draw acetone from the bottle. Very Dangerous! Good Luck ;Mike
bbott
01-29-2002 18:18:14
Likely you'd have quite a time swapping regulators.
The threads on the tanks are the opposite hand to prevent you from getting the regulators crossed.
Jerry Pilkenton
01-29-2002 13:36:16
The answer would be no. Acetylene is a very unstable gas above 15 lb's . Acetylene reg's are
designed to deliver no more than 15 lb's pressure.
There is also other things to consider such as seat material compatibility and the extreme danger that someone might change it back to oxygen
service after it has been contaminated with acety.
If that should happen it would be a bomb attached
to a cyl. of oxygen. Just because they look the same does not mean they are.
john_t
01-29-2002 13:56:32
 Re: Re: oxy/acet regulators... are they interchangeable? in reply to Jerry Pilkenton, 01-29-2002 13:36:16
Thank you...that's the info I was looking for and the reason I asked.
T_Bone
01-29-2002 16:56:56
 Re: Re: Re: oxy/acet regulators... are they interchangeable? in reply to john_t, 01-29-2002 13:56:32
Hi john_t
You got the correct info as it can not be used the way it is now!
But take your acetylene reg into the welding supply shop and see what they want to fix yours and also take the spare oxygen reg and see if they can use it for parts or in trade to fix yours!
Also do NOT use your acetylene reg they way thats it's acting now. too risky!!!
T_Bone
