Stationary Engines Discussion Forum
Wisconsin THD minimum compression
Steve Ranker
12-10-2005 16:37:25
can some one tell me what the minimum compression that will run this engine should be?
Tramway Guy
01-31-2006 19:54:59
 Re: Wisconsin THD minimum compression in reply to Steve Ranker, 12-10-2005 16:37:25
Don't forget that compression also varies with altitude.....
senlim
12-13-2005 12:31:27
I used to work for a Wisconsin distributor.
From memory most Wisconsin engines seriously loose power below 100 psi and get very hard to start below 70 psi.
Hope this helps.
jerrrycpp
12-13-2005 11:27:10
I bought a genuine Wisconsin service manual to get this exact information. As I remember it, the book said something to the effect of: "Due to the variables encountered in engine usage and wear, an exact number would not help. Be sure it has sufficient compression to produce the power needed." So much for OEM information. I'm looking forward to anyone's answer.
Glen in TX
12-13-2005 12:39:12
 Re: Wisconsin THD minimum compression in reply to jerrrycpp, 12-13-2005 11:27:10
Most compression tests on multiple cylinder engines are figured at a free cranking speed with a electric starter in good shape spinning the engine over with other spark plugs removed. How would one know how fast to turn the engine with just one cylinder and hand crank for an efficient test is what I'm getting at? Wonder what they do on the new Wisconsins? www.wisconinmotors.com
Glen in TX
12-11-2005 08:49:24
It makes no mention of a compression test in I&T manual on T series engines. I&T Large Air Cooled Engines 1988 & prior service manual LES1-4. Intertec books dot com. Other manuals: www.continentalengines.com and www.wisconsinmotors.com
