Stationary Engines Discussion Forum
carb governer and pops throught the muffler
vi n
12-06-2005 15:06:08
The governer on an 8hp Tecumseh keeps going back and fort at all speeds and it pops or snaps throught the muffler what can I do with these problems
fzbcheve
01-07-2006 15:15:43
 Re: carb governer and pops throught the muffler in reply to vi n, 12-06-2005 15:06:08
back firing, all most always is a lean condition. check the idle circuit, as the engine runs on it most of the time.
bwegher
12-08-2005 12:07:01
Also, the fuel tank must be vented thru the cap.
Sometimes the cap is plugged.
Bob
12-07-2005 08:29:46
Check out the "technical forum" at the site linked below. There are several Tecumseh experts there who can give detailed intructions as to how to thoroughly clean the carburetor. Worst case, though, some clogged Tecumseh carbs simply need to be replaced.
Kent of SW MO
12-07-2005 06:14:18
Hunting govener on a Tecumseh engine is almost alway a plugged idle mixture circuit in the carb. They can be VERY hard to clean as the hole through which the idle fuel flows is VERY small.
Kent
doogdoog
12-06-2005 18:23:42
Aloha, I would check if it is getting enough fuel (filter?) or it could be the carb (main Jet dirty or needs adjustment?). Was it running ok before it started to act up (just getting it out of storage?)or did it suddenly start acting up while running ok.
Mahalo,
doogdoog
The Answer Man
12-06-2005 18:13:14
 SIMPLE... in reply to vi n, 12-06-2005 15:06:08
Take it to a good repair shop.
