Stationary Engines Discussion Forum
Wisconsin THD worth rebuild?
JimCT
11-30-2005 16:25:37
Fiiend of mine has a THD on a NH 66 bailer which needs a rebuild. Engine autopsy showed worn out crank & rod bearings, scored crank cyl. walls. Question is if the engine is worth rebuilding? Are oversize bearings & rings still available at reasonable cost? The engine is complete but just tired. Seems a shame to junk it. Advice needed.
havvey
12-02-2005 15:01:06
 Re: Wisconsin THD worth rebuild? in reply to JimCT, 11-30-2005 16:25:37
you would be better to pick up some used ones i will have 3 to sell that way you have parts or get a good used running one. Gasket rings etc is not bad if you do your wn work. but machine work is more than there worth. Just as an aside i may have a baler with one on it to resell too. contact me if you want.
JimCT
12-03-2005 14:04:02
 Re: Wisconsin THD worth rebuild? in reply to havvey, 12-02-2005 15:01:06
Thanks for the info. & offer Havvey. Think maybe we will put a PTO setup on the bailer and be done with it. Next thing will be to try to find the bolt-on slip clutch & PTO shaft for the bailer (old NH 66).
havvey
12-03-2005 14:14:59
 Re: Wisconsin THD worth rebuild? in reply to JimCT, 12-03-2005 14:04:02
up hear you couild find one there is an outfit in pa that sells used baler parts I actully have at least part of a drive line for a 66 or 68.
JimCT
12-03-2005 16:29:55
 Re: Wisconsin THD worth rebuild? in reply to havvey, 12-03-2005 14:14:59
What parts do you have? Do you have a phone number for the parts outfit in PA?
havvey
12-04-2005 06:59:54
 Re: Wisconsin THD worth rebuild? in reply to JimCT, 12-03-2005 16:29:55
i will have to did out the number and i will have to look at the drive line unit it is in storage. you can email me if yo want [email protected]. if you scrap that tfd engine i may need the side mount gas tank.
JinCT
12-04-2005 07:31:50
 Re: Wisconsin THD worth rebuild? in reply to havvey, 12-04-2005 06:59:54
Sounds good. Will talk to my friend to see if he wants to part out the Wisconsin.
Kent of SW MO
12-01-2005 05:34:13
Wisconsin are expensive to rebuild. Check out the cost and then see howbad you want to fix it.
Kent
