Stationary Engines Discussion Forum
wisconsin VG4D clutch
wally altom
11-08-2005 16:18:01
where can I find a cluch for this motor; it was orginally on a generator
JOB
11-09-2005 17:57:30
 Re: wisconsin VG4D clutch in reply to wally altom, 11-08-2005 16:18:01
Before you can put a Rockford clutch on that engine you will need to change the engine block and the crankshaft. If I am wrong someone out there can correct me.
Steve-Maine
11-10-2005 09:42:26
 Re: wisconsin VG4D clutch in reply to JOB, 11-09-2005 17:57:30
JOB is right.
The block must have holes drilled in rear for the bell housing. and crankshaft must be the right length, usually fairly short with a center hole in crank and threads in it to bolt to clutch. Might be easier to find another block and crank. I just sold a bunch of these to a fellow in South Portland,Me
ronnie269
12-03-2005 18:44:52
 Re: wisconsin VG4D clutch in reply to Steve-Maine, 11-10-2005 09:42:26
I think I have one, will check tomorrow! E-M me back incase I forget!
[email protected]
