Stationary Engines Discussion Forum
Will this work?
TwinCreek
11-03-2005 06:06:01
I have a 2 HP Fairbanks Morse model Z engine that I have almost ready to run. I do not have a gas tank for it yet. Can I hook up a remote gas tank to the fuel line that originally was in the Fairbanks gas tank? I know the original fuel line has a stainer with a ball check. Do I need this with the remote fuel tank or how should I hook up the tank until I get an original tank for it? Thanks for your help.
bwegher
11-03-2005 20:10:28
 Re: Will this work? in reply to TwinCreek, 11-03-2005 06:06:01
Any tank will work with the original fuel pick-up tube. Even a small soup can of gas will work.
If you want to remove the original tube and attach a copper line, then the level of gas to the carb should be about the same height as the needle valve, NOT higher or the gas will just drain into the carb. It's better to use the original check-ball pick-up tube.
