Stationary Engines Discussion Forum
Wis. VE4, VF4 (Attn J. Schwiebert)
Mike Spencer
10-18-2005 18:51:14
J. Schwiebert: Do you still have the Wisconsin VE4/VE4D manual you mentioned early in the year?
Send me email if you do.
- Mike Spencer
jdemaris
10-23-2005 06:01:20
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to Mike Spencer, 10-18-2005 18:51:14
I'm not Mr. Schwiebert, but I have all the older Wisonsin manuals and I worked for a Wisconsin dealer back when they were current, and not "antiques" or collectibles. What do you want to know?
Mike Spencer
10-23-2005 19:27:22
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to jdemaris, 10-23-2005 06:01:20
What's the horspower for a VE4D? (Online info varies from 21HP to 30HP).
What's the peak power RPM? I'd like to run it at about 1800 RPM but not if that's significantly far down the power curve. I gather max loaded RPM is 2400. Where is that on the power curve?
How does the governor work? Looks like it depends on oil pressure. Is that right?
Anything else that I don't know that I don't know.
Is the flywheel taper standard SAE 1.5" per foot (a la Machinery's Hbk)? (I may need to have the flywheel bushed and re-bored.)
Is the flywheel Woodruff key non-standard? I had to hand-make one. Seems to be 1-3/8" diameter by 9/32" thick. Standard seems to be either 1/4" or 5/16" thick.
There are 4 timing marks -- 12:00 o'clock, TDC for each bank and one other. Is the "other" one correct for dynamic (strobe lite) timing on a distributor engine?
Are there any specs or guidelines for how much starting torque the clutch will handle?
I want to try to rig this up to run a 300# Alldays & Onions air hammer (see the URL) that once had a 15HP 3ph electric motor on it. I'm looking at a roller chain and sprocket speed reduction to ca. 900 RPM. 1800 RPM would make for a nice 2:1 ratio and also make selection of sprockets and chain easier.
This engine allegedly has only a few hours on it after a complete rebuild. I expect to get an older, crank start VF4D in unknown (but not seized) condition. But for my situation, electric start is a big asset.
- Mike
http://home.tallships.ca/mspencer/shop/alldays.html
jdemaris
10-25-2005 12:54:01
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to Mike Spencer, 10-23-2005 19:27:22
I forgot to mention, the standard woodruff key #23 that I mentioned specs. out (according to my chart) as follows: It is a flat-bottom key, not a full radius key, number 23, USA Standard number 1011, 5/16" x 1 3/8" , actual length and height is 1.362" by 0.584" , package of 10, part number 98481A245 cost $6.45 at Link
jdemaris
10-25-2005 12:36:56
The original Wisconsin manuals are not exactly "comprehensive." I'll answer what I can. The VE4 specs should be the same as VE4D since the "D" only designates the use of Stellite exhaust valves. So, a VE4 used AE-75B valves for both intake and exhaust, whereas a VE4D uses AE-75D exhaust valves.
Horsepower for VE4 series is: 13 at 1400 RPM, 15 at 1600 RPM, 17 at 1800 RPM, 18.7 at 2000 RPM, 20.5 at 2200 RPM, and 21.5 at 2400 RPM which is the maximum. The VF4 ranges from 15-25 horse.
The governor is purely mechanical and does NOT work on oil pressure. It is a centrifugal flyball governor. The governor control arm has twelve holes in which the spring can be hooked depending on the RPM at which the engine is to be used. The holes from bottom to top are numbered 1 to 12. You pick the hole depended on what the intended loaded RPM is to be (or add 150 RPM for the unloaded). 1400 RPM - hole 4, 1500 RPM - hole 5, 1700 RPM - hole 6, 1800-1900 RPM - hole 7, 2000-2100 RPM - hole 8, 200-2300 - hole 9, 2400 - hole 10. I don't have the specs on the cranshaft or flywheel bore taper. Flywheel key is a standard #23 Woodruff key, Wisconsin part # PL-83. Ignition timing is TDC when idle, and 27 degrees BTDC at full advance regardless if magneto or battery-distributor ignition. Below 500 RPM, the engine runs at 12 degrees BTDC.
Mike Spencer
10-25-2005 21:53:23
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to jdemaris, 10-25-2005 12:36:56
Thank you very much, jdemaris. The power curve and governor linkage info will be a great help.
It looks like the VE4D may be borderline for my purpose, barely powerful enough. Perhaps I can devise a compression release on the hammer to reduce starting torque that might overload the engine.
- Mike
jdemaris
10-26-2005 05:20:14
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to Mike Spencer, 10-25-2005 21:53:23
If you are going to do all the work of finding and/or getting an engine running, why not use a bigger engine, e.g. a VP4, VR4,VG4, VH4 or even an overhead valve engine like the V461 (60 horse) or V465 (65 horse)? They are not uncommon, at least not here where I live in central New York. I often pass up chances to get the bigger ones simply because they are so heavy. I saw two good electric-start VR4s get thrown out last week (56 horsepower). I have a neighbor that was thinking of getting rid of a lot of "extra" stuff he's got in his barns, and he asked me a few days ago if I wanted his Wisconsin engines - I think he had two VP4Ds, one crank start and one electric start. The latter was rebuilt about 15 years ago and put away in storage - i.e. never used. He wanted $50 for the pair and I didn't take him up on it. If they had been two-cylinder engines, like TEs, TFs, TJs, etc. I would have bought them.
Mike Spencer
10-26-2005 11:14:09
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to jdemaris, 10-26-2005 05:20:14
If you are going to do all the work of finding and/or getting an engine running, why not use a bigger engine...
Well, I already have the Wisconsin VE4 and getting it running shouldn't be a big deal.
I also have a big Continental 6-cyl industrial engine similar to some of the Continentals used in old tractors. It would be just perfect: low RPM, governor, heavy clutch, lots of power. The castings and moving parts are all fine except for wrist pins and wrist pin bushings. But the previous owner disintegrated a wrist pin bushing under load and there's bits of brass everywhere -- bearings, oil galleries etc. I'd rather use it but it *will* be a big deal to get it cleaned up, re-assembeled and running.
So far as exploiting the supply of old engines in NY goes, Nova Scotia is a long drive from anywhere and the US-Canadian border crossing complicates things further.
- Mike
jdemaris
10-26-2005 14:20:08
 Re: Wis. VE4, VF4 (Attn J. Schwiebert) in reply to Mike Spencer, 10-26-2005 11:14:09
My family comes from Nova Scotia - but that was a very long time ago - Port Royal to be exact.
Nothing wrong with using what you've got - in my area though, the Wisconsin engines are plentiful. When it comes to fixing up any any engine, parts are getting exspensive - used or new. I just did a mild resurection on a four cylinder Continental F162 including a valve job, rebuilding the carburetor, etc. That "minor" job still cost me a couple of hundred bucks in parts.
