Stationary Engines Discussion Forum
TJD FLYWHEEL
S/C BOB
10-04-2005 04:34:21
Can someone give me some advice on pulling the flywheel on my TJD Wisconsin two cylinder?Thanks in advance.... Bobby
zira
10-04-2005 17:16:28
 Re: TJD FLYWHEEL in reply to S/C BOB, 10-04-2005 04:34:21
It is mounted on a taper. Remove the center nut, pull on it with one hand, and hit it HARD in the center with a babbit hammer. That's the book method. I suggest you try the following:
1. Soak the heck out of it with a penetrating oil.
2. Leave the nut flush with the end of the shaft.
3. If you have or can fasten a puller, use one to put tension on the flywheel so it is trying to pull off. Not a huge amount, but some.
4. If you don't have a babbit hammer, use copper or brass.
5. Hit it HARD.
If yours has a flywheel magneto, it makes the puller part harder, be very careful of what is behind it.
David
