Stationary Engines Discussion Forum
Wisconsin Engine
Yugrotcart
09-03-2005 16:55:05
I was offered a Wisconsin engine today and I am trying to determine the HP and model number.
It's 2 cylinder,when looking from the manifold side large "squirrel " fan on left side, carb, fuel pump, dist on same side,crankcase vent tube to carb intake,large automotive type 3 bolt starter on rear, and is painted light green.
Sorry no photo yet,any ideas?
Paul
oldtractorguy
09-07-2005 11:16:24
 Re: Wisconsin Engine in reply to Yugrotcart, 09-03-2005 16:55:05
Seems to be a 10 to 14 hp shaw du all engine.
Kent of SW MO
09-04-2005 14:43:55
Late model TF, THD or may be a TJD. the way to tell is pull both spark plugs and see if the piston come to TDC at the same time or one is at TDC and the other is at BDC. If the pistons are together it is a TF or THD. BDC= bottom dead center. TDC= top dead center.
Kent
Yugrotcart
09-04-2005 16:32:22
 Re: Wisconsin Engine in reply to Kent of SW MO, 09-04-2005 14:43:55
Thanks for your help Kent. I'll get it home and check it out.
Paul
