Stationary Engines Discussion Forum
f163
therigwelder
05-25-2005 14:19:36
i just picked up a welder with a continental red seal F163.it spins over fine but is getting no fire from the coil.I have 12v going into the pos.side and 12v coming out the neg. side going to the points.this is a head mounted distributor.also this coil is brand new i just put it on cause the old one i thought was the problem.does this coil take the place of a magneto setup? need help getting fire thanks by the way the motor is a 1969
Bob
05-25-2005 19:57:55
 Re: f163 in reply to therigwelder, 05-25-2005 14:19:36
Put a test light on the side of the coil connected to the points, and verify that it flashes on and off, as the points open and close with the engine cranking over.
therigwelder
05-26-2005 11:56:17
 Re: f163 in reply to Bob, 05-25-2005 19:57:55
thanks all it turned out to be a bad condensor.she purrs like a cat now
Larry from MD
05-25-2005 15:21:09
Well the condenser has to be good too or it wont fire the coil.If you don't have the right amount of resitance in the system you will overheat the coil and burnout condensers often.So you need a reister in your wire or a coil with a built in one.
