Stationary Engines Discussion Forum
TJD Wisc. stalls out
Pastene Pest Co
04-26-2005 19:19:49
I have a TJD Wisc. Spec. #331739 that I have mounted to a spray rig used for pest control. I Sprayer unit was assembled in 1974. The motor turns my "Bean" piston pump at 750-1000 RPM. Has worked well for me until recently. Starts, idles, revs great, but when I engage the pump putting the motor under a little load after about 10-15 mins. the motor stumbles for a few secs then dies. starts right back up, but as soon as I engage it stalls, until cooled.
Kent of SW MO
04-27-2005 06:42:18
 Re: TJD Wisc. stalls out in reply to Pastene Pest Control Dav, 04-26-2005 19:19:49
Check fuel pump, may be vapor lock. Also check the coil,condensor if battery ignition or if a mag it could have a bad coil or condensor.
Kent
