Stationary Engines Discussion Forum
unknown john deere hit and miss
mattd
03-15-2005 19:13:16
today i was at a friends house. i was looking around in their old shed and saw a john deere hit and miss engine. i didnt look at it to close for a serial number tag(if they even had them). what model could this be. it has about 14 inch flywheels, a magneto, enclosed crankcase. how much should i ask for it? thanks for any help
matt
havvey
03-15-2005 19:40:32
 Re: unknown john deere hit and miss in reply to mattd, 03-15-2005 19:13:16
probably a 1 1/2
Doug Waggonner
03-15-2005 20:48:00
 Re: unknown john deere hit and miss in reply to havvey, 03-15-2005 19:40:32
Offer him $100 and go from there. Not knowing if there are any cracks, breaks or welds? There is ALOT of different factors that go into an engines value. Almost any complete old engine is worth $100. If its complete, not busted or broke I wouldnt go higher than $300. On the JD model "e" engines the name is worth more than the engine its self. And the MAG is worth more than that. They are a good starter engine for someone wanting to get into the engine hobby. Since all the parts are being reproduced and easy to get. The serial # is on the MAG side on the engine on the govoner cover behind the flywheel. Unless its the early model that has the tag on the back of the engine below the gas tank fill hole. I think if they didnt have the JD name on the side of them nobody would have bought them, they are cheap built, oil sling'n, bad magneto "sobs". I should know I have one! lol Good luck.
T.Sherman
04-17-2005 19:29:13
 Re: unknown john deere hit and miss in reply to Doug Waggonner, 03-15-2005 20:48:00
I have started lurking around the hit and miss forum looking for something on the JD engines,Maybe I should have looked more before I bought the ones that I did if they are as you described. I asked a Mr, Voight a question from one of his posts on the JD tractor forum and got a nice personal response from him. I collect JD tractors and stumbled on a set of 3 Deere engines plus a Waterloo Boy which I think is a 2 hp. I will most likely annoy someone by asking so many questions about them as I have never owned or even started a hit and miss engine.
