Stationary Engines Discussion Forum
Wisconsin 2 cyl Engines
Al Boy
01-23-2005 16:38:53
What is the difference between a model TFD and a THD?
Chris Rockholm
02-21-2005 10:53:39
 Re: Wisconsin 2 cyl Engines in reply to Al Boy, 01-23-2005 16:38:53
Does anyone have the following information on a THD 2 cyl 3.25/83 54 ci 833 cc motor:
Engine timing procedure
I am rebuilding an old motor and cannot locate this info on the web.
Thanks,
zira
01-24-2005 15:21:48
THD is newer, higher compression, diffent bearings, different connecting rod bearings, timed different, higher rpm, more hp. Some parts are interchangeable, and some "almost" (they use the same magneto but the drive gear is different, for instance). Same basic footprint & PTO.
