Stationary Engines Discussion Forum
wico mag
mike mtk
01-09-2005 14:51:44
I have a wisconsin engine type ak. I has a wico mag on it. Been having a lot of trouble with spark if I pull it off and take it in and have somebody go through it will it be hard to retime it. Any advice would be appreciated.
zira
01-10-2005 15:40:49
 Re: wico mag in reply to mike mtk, 01-09-2005 14:51:44
It is not difficult to retime it, I can scan those pages from the manual & e-mail them to you.
90% of the time, this is the points. Clean them well with fine sand paper (320 or finer) until they are shiny, then carefully spary with brake cleaner or carb cleaner. Check the gap & try. If that doesn't work, replace the condensor (cheap). A rebuild is expensive, try fo find someone who will tinker with it without commiting to a full rebuild unless you want to drop $100 or so. These are pretty robust mags, they rarely have any major problems unless they are really trashed.
Mikemtk
01-11-2005 18:53:54
 Re: wico mag in reply to zira, 01-10-2005 15:40:49
Zira let me know what you need to do that. A little new at this. Will this mag have magnets in the flywheel, could'nt get wheel off.
zira
01-12-2005 15:26:07
 Re: wico mag in reply to Mikemtk, 01-11-2005 18:53:54
You don't have to take off the flywheel. The mag is held on with one through bolt & one stud with a nut on it. You can work on it while it is still on the motor, but I usually find it easier to take them off. Is your mag a "C" with the oval cover, or an XH with a one-piec plastic cap?
E-mail me at zira at bellsouth dot net & I will scan the info to you.
mikemtk
01-13-2005 19:40:18
 Re: wico mag in reply to zira, 01-12-2005 15:26:07
zira i tried e-mailing you but my computer won"
t let me send it for somereason. I have the C mag a little oval cover. You can e-mail me at [email protected]. So far I haven"t had any trouble reciving mail.
zira
01-14-2005 03:26:25
 Re: wico mag in reply to mikemtk, 01-13-2005 19:40:18
Well, your e-mail bounced back to me too. I am un-hiding my address for this post, try e-mailing me again.
zira
01-16-2005 15:07:25
 Re: wico mag in reply to zira, 01-14-2005 03:26:25
I e-mailed you a couple scan's, and I didn't get an error message so hopefully you got them. If you did not, let me know & I will put them in the US mail.
