Stationary Engines Discussion Forum
Wisconsin VH4D piston
Tom/Idaho
01-06-2005 05:15:18
Why do the pistons have a slot cut in them ? The one I just took apart had the slot pointing up with the 'front' arrow pointing to the rear of the motor. My repair manual does not cover this and says the flywheel side is considered the front of the motor. I am ready to assemble and if the pistons were 180 out I don't want to put them back in that way. Any help would be appreciated, Tom/Idaho
Don Voit
01-09-2005 13:40:16
 Re: Wisconsin VH4D piston in reply to Tom/Idaho, 01-06-2005 05:15:18
the slots go away from the thrust side you will have 2 up and 2 down when installed correct on a v4 wisconsin
Bob
01-06-2005 08:04:30
The slots are to allow for thermal expansion in the HOT engine, and are cut in the lightest-loaded side of the piston. That's why they are to be installed per manufacturer's instructions.
Tom/Idaho
01-06-2005 12:38:09
 Re: Wisconsin VH4D piston in reply to Bob, 01-06-2005 08:04:30
So then, the slots go down for the 'front' arrow to point to the flywheel? Thanks Bob, I appreciate your help. Tom/Idaho
