Stationary Engines Discussion Forum
Wisconsin VF-4
Trev
01-05-2005 10:35:58
Bought an old welder with a Wisonsin VF-4 engine that was all gummed up and not working.
I thought I had done a desent job of cleaning it all up. Valves and head gaskets in good shape and re-lapped them.
But still getting poor compression on all four cylinders.
Question,..how fine a finnish do these cylinders require??
Question,...How much end gap is reasonable before they loose their sealing ability.
I'll be thaking the thing appart again to see if I can sort this problem out. Just seems strange that all four are equally poor after being cleaned up.
Trev
Roberts Creek, B.C.
Don Voit
01-09-2005 13:46:07
 Re: Wisconsin VF-4 in reply to Trev, 01-05-2005 10:35:58
the rings are stuck
Trev Berry
01-13-2005 20:26:44
 Re: Wisconsin VF-4 in reply to Don Voit , 01-09-2005 13:46:07
Don,
Thanks for the reply, but no the rings aren't stuck.
I've taken it apart again and see that the end gaps are 1/8th inch or so. Thats way too much for it to work.
I would believe that it should be around .015 inch or maybe a litttle larger since the cylinders would run hotter than a car engine.
So I will have to keep a look out for piston rings.
Local suppliers want $150CAN for the set.
Not too economical to pay more for rings than the whole welder and not too sure how it all will work.
Trev
Don Voit
01-14-2005 11:18:20
 Re: Wisconsin VF-4 in reply to Trev Berry, 01-13-2005 20:26:44
yes 1/8 in is too much too bad we are so far apart. I have a lot of used parts for the vf4 , but not new rings. how bad are the cyl wore?
MF 711
01-30-2005 07:12:32
 Re: Wisconsin VF-4 in reply to Don Voit, 01-14-2005 11:18:20
Check out EBAY for Wisconsin Parts, I was able to get all my parts to rebuild my VF4 at less than 1/2 can price Don
