Stationary Engines Discussion Forum
Wisconsin VH4D compression
Tom/Idaho
12-21-2004 05:44:01
Wisconsin VH4D Serial # 3327992. I have 80+# on all four cylinders. What is normal compression?
One cylinder has been blowing oil past the spark plug threads (plug is tight) but it still runs great, just smokes a lot. I'm thinking I might have a spark plug or wire problem since all cylinders have the same pressure. Any suggestions. I guess rings and valve job are in order just did'nt want to do it cause it runs so good. Thanks, Tom/Idaho
Bob
12-21-2004 12:02:57
 Re: Wisconsin VH4D compression in reply to Tom/Idaho, 12-21-2004 05:44:01
If it's blowing oil past the spark plug, the spark plug is simply not sealing to the head. Is there a unseen crack, or a missing gasket? Have you tried another spark plug?
No matter WHAT compression it has, the leak at the spark plug is not due to the compression, or oil consumption. It is simply a sealing problem, and if the engine is running OK otherwise, you just need to fix the leak!
