 Hello folks, It seems as if most of the Witte generators that are being rebuilt are a fair bit older than the generators I recently acquired and am hoping to rebuild. Here is what I know about these generators: They were purchased 8-10 years ago at an auction in Nova Scotia (where I reside). At the time there was a large box of parts that came with them, including cylinder sleeves, injector pump parts, cylinders, connecting rods, etc - but the guy that had the generators got tired of tripping over them in his garage and chucked them :-| Neither of the 2 generators I have are seized, and I am not worried about rings, or sleeves, or any of that stuff, but I do need injector pumps.. Below is the information provided on the generator itself: WITTE ENGINE CORP. Serial No: - 538 - 11EE (Generator 1) - 538 - 13EE (Generator 2) Part No: 403 � 741 - it is A/C - 20.6 K.V.A. - 16.5 K.W. - 120/208 Volts - 57 Amps - 60 Cycle - 3 Phase And the following is the information on the engine itself: Model: 120 Bore: 4 � 3/8 Stroke: 4 Lube Oil Cap � Qts: 16 Coolant Cap � Qts: 20 HP: 26 RPM: 1800 Serial - 35014 (Generator 1) - 44080 (Generator 2) So I guess if anyone has ANY idea where I may be able to get parts for these, PLEASE post. I don't care if I keep these origional or not - I will use a different Injector Pump if someone knows of something that will work. We plan on actually using at least one of these generators - so whatever works is good enough!
