Stationary Engines Discussion Forum
Wisconsin one cylinder engines
xc
11-16-2004 19:02:10
Saw two today, one with a hand clutch, looked to be about 6-8 hp, both had good compression but weren't running, spark plug at about a 30 degree angle on the side of the head. One had the letters "AKN" on the metal cover, couldn"t get the serial numbers. These things worth $50 each? Thanks for any help.
zir
11-17-2004 15:36:39
 Re: Wisconsin one cylinder engines in reply to xc, 11-16-2004 19:02:10
Probably, although not a lot more usually. The AKN is about 6 hp. There was also an ABN (smaller bore, less horsepower), and earlier AB & AK. They are not real rare but are different looking & usable. Air cleaners can be hard to find/expensive, as can be gas tanks. GAskets, rings, etc. are still available, and teh mags are usually easy to fix. E-mail me if you need any specific info at zira at bellsouth dot net.
thanks
11-19-2004 17:41:04
 Re: Wisconsin one cylinder engines in reply to zir, 11-17-2004 15:36:39
for the info!
