Stationary Engines Discussion Forum
flywheel needed for wisconsin TF engine
Ken Lower
11-12-2004 05:07:07
I am In the need for a flywheel for a TF w/o starter ring. It has a
lot of broken cooling fins and it vibrates. Is this a common
problem? The engine is on a Shaw Du-all R12T tractor with lots of
accessories. Any help would be appricated. Thanks
Christopher G
11-12-2004 18:57:39
 Re: flywheel needed for wisconsin TF engine in reply to Ken Lower, 11-12-2004 05:07:07
Ken, I should have a correct flywheel for your TF two cylinder Wisconsin. I believe the one I have is not equipped with electric start so it should be correct for you. I have several WI parts and would be glad to help, as I have a strong like of any vintage iron. Broken fins are common and will set your engine out of balance in a big hurry. Thank You, Chris.
Ken Lower
11-15-2004 07:51:05
 Re: flywheel needed for wisconsin TF engine in reply to Christopher G, 11-12-2004 18:57:39
Hi Chris
Shoot me a E-mail and see if we can make some arrangements. Thanks Ken
Christopher
11-16-2004 07:24:41
 Re: flywheel needed for wisconsin TF engine in reply to Ken Lower, 11-15-2004 07:51:05
Ken, YT Forum won"t show me your email. You may have to uncheck the "hide" blank. Or include your phone #. Whatever you are comfortable with. Thank You, Chris.
Ken Lower
11-18-2004 10:43:06
 Re: flywheel needed for wisconsin TF engine in reply to Christopher, 11-16-2004 07:24:41
Hi Chris
Phone # 585 637 2667
E-mail: [email protected]
