Stationary Engines Discussion Forum
fairbanks morse d timing
R Rahmier
10-28-2004 18:54:51
can anybody tell me if a fmj mag suppose to have a impulse? and how do you time it I see some yellow paint on the gear inside the case is this the timing mark
rhudson
11-04-2004 08:59:19
 Re: fairbanks morse d timing in reply to R Rahmier, 10-28-2004 18:54:51
lacking information on the fbm-118 i am working on, i just timed for top dead center on the compression stroke. the impulse mechinism on my 118 is located on the outside of the mag case and consist of a spring loaded drive shaft, a pawl and a pawl catch. the pawl is centrifugal sensitive and will lock on the catch, load the spring and then release to form the impulse. it also retards the mag during this spring loading. so as the rpm speeds up the mag stops impulsing and also advances the timing.
Zira
10-29-2004 16:52:47
The ones on Wisconsin engines have an impulse coupling to aid in starting, I think all FMJ series mags have it.
