block casting for mystery engine BA-51-A F-24 Is this correct for TF or one of the series? I have two partial sets of sheet metal but no blower housing. One set says it is a TF engine. The other set has no tag. The piston is 3 1/4 so it could be TF or THD. The technical data information for the ASECC site has the wrong piston size for the wisc tf engine, and this lead me astray for a while (and thinking I had a larger and newer engine). Have not checked the stroke. Other than block numbers, can not find id which of TF through THD series. The magneto is FM x1 2B7. This engine obtained from an estate and the deceased had not located rods and pistons at the right price. It was disassembled but the son and grandsons gave me everything under the bench and in the pile. some things were missing, such as the starter, intake manifold, oil pump, and all the da___ bolts for the whole engine. I am looking for parts motor just for all the bolts. There were at least two engines. The rods did not come off the short block I did get as that engine crank and cylinders would have been ruined for lack of oil.
