Stationary Engines Discussion Forum
Understanding Governors.. FM ZC
packrat56
10-12-2004 07:15:44
I am new to these engines, and I am not sure I understand the system. I have a FM Zc, it is set up so that a spring holds the throttle plate closed, and when the weights of the governor move out with incresing RPM the throttle plate opens more, seems backwords? Is this correct, or is something backwords from the last owner? The governor is broken, where can I get parts for this governor? It is a 1929 FM ZC.
Thanks for any help!
Bob
10-12-2004 08:13:38
 Re: Understanding Governors.. FM ZC in reply to packrat56, 10-12-2004 07:15:44
Something is backwards.
The outward movement of the weights should CLOSE the throttle.
Fairbanks Morse no longer supports the old engines, but on their website,
Link
if you scroll to the bottom of the page, they have links to outside companies that have parts and possibly information on the old engines.
Packrat56
10-14-2004 06:28:47
 Re: Understanding Governors.. FM ZC in reply to Bob, 10-12-2004 08:13:38
I took apart the fuel mixer, the throttle plate is held CLOSED by the spring when disconnected from the rod, is this correct?
