Stationary Engines Discussion Forum
VF4D Questions
Trackerfive
08-31-2004 10:03:57
Does anyone know what the difference between a VF4d and a VE4? I have Two engines and was wondering if the parts could be swapped. I was Also wondering how you change the poured babbit rod bearings.
Zira
08-31-2004 15:14:19
 Re: VF4D Questions in reply to Trackerfive, 08-31-2004 10:03:57
The VE has a smaller bore than the VF. Most parts (other than piston & cylinder) are the same. The "D" means stellite ehaust valves, if your VE4 isn't a "D" then it had regular exhaust valves. What were you trying to swap?
trackerfive
09-01-2004 05:56:52
 Re: VF4D Questions in reply to Zira, 08-31-2004 15:14:19
I wanted to switch the crank shaft and rods. the rod bearings are babbit bearings. I don"t know how to change them. Thanks for your help
