Stationary Engines Discussion Forum
Wisconsin VG4D Head
Matthew Tyma
08-08-2004 08:18:19
I am having a problem with a Wisconsin VG4D Motor. For the third time the left head has blown a hole through itself. I have tried spot welding and Aluminum welding the hole closed but with no lasting results. The hole keeps blowing through in a line between the sparkplug and the dividing wall between the heads. My first question would be what the heck causes it (my thought is metal fatigue) The second question is where can I purchase a new (used) head without buying the whole motor. Any help with either question would be greatly appriciated. Thanks.
Tramway Guy
09-01-2006 06:33:48
 Re: Wisconsin VG4D Head in reply to Matthew Tyma, 08-08-2004 08:18:19
Is all the sheet metal shrouding in place? This is very important for any air-cooled engine..
Secondly, you might have excessive carbon in the cylinder; on the piston or the inside of the head.
There were at least two different heads used on this engine. The standard, and the high-altitude (or LP-gas) head. Different casting numbers.
jmck70eb
08-31-2006 12:11:08
I'm having the same problem with my vg4d except it's blowing out towards the top left side of the head. mine will run for about 30 min or so than the gasket blows out, it's happened 3 times now and one of those times I had to fill in a gouge in the head that was melted/blown out. I put a straight edge on the head & block everytime to make sure its not warped and it looks good plus I checked the advance and it's working so I'm at a loss for ideas. I do know that that corner of the head is getting hot because the bolts seem heat stress when I removed them, they had a rusted color look and came out hard, the metal covers are all on and the fan is turning so its getting air circulating over the motor. I torqued the head bolts to 35lbs the first time it blew than 40lbs second time. Anyone have any ideas?
Benj. J. Joe Browning
08-08-2004 13:07:35
Hi Matthew, The best person to contact is Tim Stine at Rock Creek Consulting. His email address is [email protected]. His number is 814-766-3675. He has everything, new and used,for Wisconsin Engines. Hope this helps.
Joe
Bob
08-08-2004 13:18:53
 Re: Wisconsin VG4D Head in reply to Benj. J. Joe Browning, 08-08-2004 13:07:35
B.J.J.B.,
What a co-inkydink! You will notice that's who the ebay link is to!
Bob
08-08-2004 08:27:40
There's a guy selling Wisconsin stuff on ebay, says he has lots more not listed. Might be worth contacting him for a head.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41505&item=3831607257&rd=1
Jon H
08-08-2004 09:35:57
 Re: Wisconsin VG4D Head in reply to Bob, 08-08-2004 08:27:40
Make sure the advance mechanism in the distributor is not rusted/stuck. I have had this happen with engines stored/used in damp conditions. With the advance stuck in the full advance position,they will detonate hard enough to break heads. With the dist cap removed,twist the rotor in the direction of distributor rotation. The rotor should move about 10 degrees,then snap back to the retarded position when released. If it is stiff or stuck,work penetrating oil onto the hollow shaft under the rotor.
