Stationary Engines Discussion Forum
Wico mag XH-150C Application needed?
MMB
07-13-2004 09:31:51
I have a little mag here that I assume is from some stationery engine so I posted here. It is a Wico model X, specifically a XH150C model. It is for a one cylinder engine. A tag on the side shows it to have a 29 degree impulse. It also has an engine manufacturers number Y-58. Has a little bakelite thumbscrew for grounding. Mag is bottom mount with a couple of male lugs for connecting to whatever drives it. Any help identifying what it is from would be appreciated.
Zira
07-13-2004 15:20:32
 Re: Wico mag XH-150C Application needed? in reply to MMB, 07-13-2004 09:31:51
Wisconsin AD, AE, AF, AG, AH, ADH, AEH, AFH, AGH, & AHH. Most common are AEH & AHH. The Y-58 is the Wisconsin part number (all Wisconsin mags used a Y- number).
MMB
07-14-2004 04:11:50
 Re: Re: Wico mag XH-150C Application needed? in reply to Zira, 07-13-2004 15:20:32
Thanks for the help on this one. I think I'm going to try selling this mag on the classifieds here at YT and now it would be easier to advertise with the engine models available. Not being too familiar with stationery engines, could you give an idea of what a fair asking price would be? Mag seems in good shape, complete and with good spark.
Zira
07-14-2004 14:10:31
 Re: Re: Re: Wico mag XH-150C Application needed? in reply to MMB, 07-14-2004 04:11:50
$20 - $50, depending on condition. You might also try to sell on ASECC.com or Harry's Little Engine Ads - or e-bay as a last resort.
MMB
07-16-2004 15:13:42
 Re: Re: Re: Re: Wico mag XH-150C Application neede in reply to Zira, 07-14-2004 14:10:31
Thanks for those tips. Got a question for you on this mag here since I'm not too familiar with magnetos. When I take the cap off there is a small spring that in this case seems to be the only thing making a connection between the inside coil contact point and the wire exit location on the inside of the cap (the spring is attatched to the inside of the cap). Is this spring the part which carries current out to the plug wire or is there supposed to be some sort of carbon block that sits in that spring somehow? Seems I remember seeing those kinds of things in other mags but I can't really remember.
Zira
07-19-2004 14:50:55
 Re: Re: Re: Re: Re: Wico mag XH-150C Application n in reply to MMB, 07-16-2004 15:13:42
If I understand your question, yes the spring is the "ouput wire". It connects to a copper piece in the cap, that goes to the spark plug wire.
