Stationary Engines Discussion Forum
Timing
landmagget
05-21-2004 06:10:35
Wisconsin Model THD. How do I go about setting the timing. Where are the timing marks and at what degree?
Kent of SW MO
05-21-2004 07:01:58
 Re: Timing in reply to landmagget, 05-21-2004 06:10:35
Magneto or battery ignition? If a mag I retard the mag. as far as it will go. Then turn the engine to top dead center and then turn the engine a little farther so it is slightly after TDC. Next I advance the mag until the impluses snap. Hold the mag. in this position and tighten. This will keep the engine from " kicking" if started with a hand crank.
Kent
Jeff
05-24-2004 19:53:18
 Re: Re: Timing in reply to Kent of SW MO, 05-21-2004 07:01:58
I have an 18 hp wisconsin on a yazoo lawn tractor, the engine was rebuilt two years ago but I'm having trouble with it over heating now, the tractor and engine are like new and I hate to get rid of it. can you help!
Kent of SW MO
05-25-2004 16:07:52
 Re: Re: Re: Timing in reply to Jeff, 05-24-2004 19:53:18
Remove all the tin shrouding and make sure all the cooling fins are clear. Also be sure all the fan blades are on the flywheel. Also check that the fuel mixture is rich enough as a lean fuel mixture can make an engine run hot. Be sure to replace ALL the shrouds. if part of the tin is missing replace it.
