Stationary Engines Discussion Forum
Replacing Fuel Lines on 20cc Trimmer Motor
Tarheel
05-12-2004 04:12:34
When I try to prime the motor it seems like I am not getting good suction from the gas tank. The motor shuts off after a few seconds after repositioning from vertical to horizontal position and when I try to go full throttle. How do you replace the fuel lines and check inside the gas tank?
Ray M41
05-13-2004 15:51:00
 Re: Replacing Fuel Lines on 20cc Trimmer Motor in reply to Tarheel, 05-12-2004 04:12:34
My Weedeater has a fuel filter in the tank attached to the fuel line. It flops around in the tank. I had to shake it to get the filter to the cap hole to grab it with long nose pliers. I replaced the line from the inside the tank through the cap hole with a piece of wire to thread it through the small hole in the bottom of the tank and then grabbed it with my long nose pliers, then just pulled it out.
