Stationary Engines Discussion Forum
Honda generator
Drill
05-10-2004 16:58:58
I was just given a Honda EM5000 generator. Owner said it quit and if I wanted to fix it I could have it. So, pulled the tank off and found big hole in the engine, blew the connecting rod off. Will probably need a short block engine replacement. Can't seem to find any info on Honda engines on line. Do any of you know of any source of used Honda engines? Checked the new price of this generator, is about $3000, so fixing it may be a viable option. Have found on other projects that Honda parts can be a little pricey. Drill
Gene Davis (Ga.)
05-11-2004 20:53:36
 Re: Honda generator in reply to Drill, 05-10-2004 16:58:58
What size and type Honda engine? Give me an e-mail. I may can put you onto a source. Gene Davis
Drill
05-12-2004 07:00:00
 Re: Re: Honda generator in reply to Gene Davis (Ga.), 05-11-2004 20:53:36
Hi Gene, thanks for the reply. It's a Honda GX 340 engine, serial GC05-3049144. I saw one sell on e-bay for $167.00, which is a good price, but to get it up here would be very expensive.
I will just keep looking through the salvage yards, maybe something will show up.
Gene Davis (Ga.)
05-12-2004 18:08:13
 Re: Re: Re: Honda generator in reply to Drill, 05-12-2004 07:00:00
That is most likely going to be a tapered shaft engine, spell that as expensive! Gene Davis
Drill
05-12-2004 21:53:00
 Re: Re: Re: Re: Honda generator in reply to Gene Davis (Ga.), 05-12-2004 18:08:13
Gene Hi. Would you know how the generator is attached to the engine shaft, spline?, keyway?, set screws? coupler?, center bolt through armature? Would any other engine fit in its place?
Gene Davis (Ga.)
05-13-2004 20:03:31
 Re: Re: Re: Re: Re: Honda generator in reply to Drill, 05-12-2004 21:53:00
Don't have a book on this engine, but would speculate on there being a precison tapered shaft and matching bore with keway and with a slight interference fit maybe in the armature and probably a center bolt into end of the shaft. Have only worked with the gx160 series engines.Some taper bores have a larger thread inside of the female side that accept a special push bolt to remove the shaft from the bore. By the way Honda engines are good, but they have gold plated prices on repair parts and the manuals are extremely expensive. The printed manuals for Honda all come from Helm Inc. (the auto book publisher), seems Honda sells only a CD for computer viewing as for what dealer told me when I got a set from him. I can understand the logic behind the name Gold Wing on their motorcycles now! Gene
Gene Davis (Ga.)
05-13-2004 20:06:51
 Re: Re: Re: Re: Re: Re: Honda generator in reply to Gene Davis (Ga.), 05-13-2004 20:03:31
By the way try this site www.planopower.com, they are in texas and have lots of honda info and parts, they may can tell you what you have got.
Thanks
05-13-2004 22:29:10
 Re: Re: Re: Re: Re: Re: Re: Honda generator in reply to Gene Davis (Ga.), 05-13-2004 20:06:51
Thanks for the info, Gene. I know from working on other Honda's that their parts are very pricey. I have a couple of Honda 4TRAX that need parts I can't afford right now.
I think I'll just put this generator in corner for now, I don't have anything invested in it yet.
Take care all, Drill_in_Alberta
Gene Davis (Ga.)
05-14-2004 20:32:00
 Re: Re: Re: Re: Re: Re: Re: Re: Honda generator in reply to Thanks , 05-13-2004 22:29:10
!0-4. I left a gx160 sitting under the bench for a year till I found a reasonably priced carburetor myself. Gene
