Stationary Engines Discussion Forum
waukesha diesel engines
Kent
05-03-2004 10:28:05
Does any know the physical size of a 135DK engine? How about what they were used for? Thanks in advance for all info!
Larry from MD
05-05-2004 10:03:18
 Re: waukesha diesel engines in reply to Kent, 05-03-2004 10:28:05
We had one for awhile I got it running and a fellow bought it to run a generator.It was a little taller and longer than an Oliver 1800 engine.It did have the older style injector pump.
Kent
05-05-2004 14:33:53
 Re: Re: waukesha diesel engines in reply to Larry from MD, 05-05-2004 10:03:18
do you know where I could find one now? by older injector pump you mean the bosch pump? would it set in a Oliver frame?
Larry from MD
05-06-2004 09:37:42
 Re: Re: Re: waukesha diesel engines in reply to Kent, 05-05-2004 14:33:53
No i don't know of one now.Yes the bosh pump.I did some measureing at the time and figured it was too long for the 1950T,1800,1850's size of tractors.I did think it would go in a 2050,2150 size.
J. Schwiebert
05-15-2004 18:10:52
 Re: Re: Re: Re: waukesha diesel engines in reply to Larry from MD, 05-06-2004 09:37:42
Last I knew the 330 was still being made. It also has a 3-7/8 bore like a 310 but has a 5 inch stroke I think. However Waukesha sold the rights to manufacture that engine as well as the 4 cylinder to 220 to Arrow.
Kent
05-17-2004 11:59:15
 Re: Re: Re: Re: Re: waukesha diesel engines in reply to J. Schwiebert, 05-15-2004 18:10:52
I did some checking on the 330. the gas model is still being made by arrow engine,but the 330 diesel model has been discontinued with only 160 or so beeing produced and those were recalled. the 330 has a 3.875 bore and a4.66 stroke. a 5 inch stoke would make it 354. thanks for the replies.
Kent
05-06-2004 11:01:09
Thanks for the info. I was hoping to find a larger cubic inch engine replacment for a 310 diesel. Do you know of any other possibilties? I would like to stay with waukesha.
Larry from MD
05-07-2004 10:01:10
 Re: Re: Re: Re: Re: waukesha diesel engines in reply to Kent, 05-06-2004 11:01:09
At one time there was a 330 made,but i have never seen or known of one.
