Wisconsin v4
Mal Wagstaff
05-29-1999 01:52:30
Hi All. I'm looking for info on a modern motor. Your pages are all I've found on the web mentioning Wisconsin motors, The engine is on a piece of plant where my friend is the maintenance man. He's only just started the job here in England UK and not come across this brand before. It's a 107.7cu air cooled v4 and runs on propane gas only, the manual we have only covers the carb version. The big problem is it won't start when hot.
He and I can't find any info on the company or dealers for spares or info.
Hoping one of you kind folk can point us in the right direction TIA
Regards Mal
paul
08-09-2000 19:09:03
 Re: Wisconsin v4 in reply to Mal Wagstaff, 05-29-1999 01:52:30
Hi Mal I would bet that I have a manual on the motor you are working on and chances are very good that I probably have the parts to fix just about any wisconsin 1 cyl 2 cyl v4 vg4d 465 ect... I stock parts for all wisconsin motors and I love to help others figure out what is the problem with there motors let me check my books tomarrow and ill get back to you good luck and make sure that you check comppression valve lash dis timming mag timming so much more to check but we will get it going !!!!!
bruce keding
06-16-2001 17:13:52
 Re: Re: Wisconsin v4 in reply to paul, 08-09-2000 19:09:03
I am looking for a head for an engine that was stock in a J20 Ditchwitch machine. I think this was an 18hp engine. Is there a specical torque sequence for these heads. Your info would be helpfull. Thank You.
Bruce
Skip
06-06-1999 13:13:44
Is it magneto or distributor fired? Sounds to me like you have problem with spark, I used several of these engines on Hay Balers here in Inidana, when the magneto would go bad they would start cold but not hot.
Hope this helps a bit, Skip
ray
10-27-1999 15:11:39
 Re: Re: Wisconsin v4 in reply to Skip, 06-06-1999 13:13:44
Older wisconsin v4 engines were quite prone to have sticking valve and valve guides when hot and would not start.
