Stationary Engines Discussion Forum
Spark dies on BS N
Kurow
01-26-2004 02:33:36
I get an OK spark to start with then it dies away to very weak or non exsistant (few seconds). Consequently engine will not fire. It is on a gen set with battery start so i can keep is turning over.
I have had mag checked over, new condenser, spark plug is new and checked various gaps. Mag setting on flywheel checked and OK.
What next! Cheers
Kent pf SW MO
01-27-2004 08:34:51
 Re: Spark dies on BS N in reply to Kurow, 01-26-2004 02:33:36
Bad coil, new cap is bad(it happens).
Kurow
01-27-2004 11:59:50
 Re: Re: Spark dies on BS N in reply to Kent pf SW MO, 01-27-2004 08:34:51
Problem solved. Opened up the points further. Running like a charm. Power crisis over!!
Gene Davis (GA.)
01-29-2004 19:51:39
 Re: Re: Re: Spark dies on BS N in reply to Kurow, 01-27-2004 11:59:50
The breaker point gap not only controls ignition timing, but also gives the coil enough time to cuild up a charge to fire the coil.
