Stationary Engines Discussion Forum
Wisconsin Robin engine
Ross Milner
12-30-2003 13:30:16
This is a Model EY44W, Spec # 800087 Made by Fuji. It is currently powering a hydraulic log-splitter I am overhauling. Can anyone tell me what HP and RPM this engine is rated at?
Thanks
Roger Creasy
02-19-2006 21:59:01
 Re: Wisconsin Robin engine in reply to Ross Milner, 12-30-2003 13:30:16
I too recently bought a power washer used from a gentlemen for $250.00. Carefully looking at this nice unit I find that the engine is a Wisconsin Robin Model #EY44W, Spec#800402, Serial#165452, Prod#EY442W2080. It has a General Pump connected to it EZ3040. I seen that the pump produces 3000psi at 4 gpm. But by looking at the websites, this pump needs a 11hp engine to run it for this pressure. The only information I have found so far is this Link According to this the EY44W is only a 7.5 to 8.1 hp. Is this correct? Any information would be nice to confirm this. The gentleman I bought this from said it was a 11 horsepower engine?? Do not understand!! Thank you for any information.
Roger Creasy
02-20-2006 17:39:50
 Re: Wisconsin Robin engine in reply to Roger Creasy, 02-19-2006 21:59:01
Found some information on this engine from a rebuilder of Wisconsin Robin Engine and is a Authorized Service Repair for many other small engines (Yanmar, Kohler, Honda, Robin, Wisconsin, Deutz, Hatz, Onan, Linamar and Lombardini). He said that the EY44W Wisconsin Robin engine is an older L Head Vertical stroke engine, 1 cylinder. It is a 11 1/2 horsepower motor that runs at 3650 RPM's. It takes a standard motor oil 30w, do not use synthetic he said. Under normal conditions, this engine should last a lifetime with proper maintenance. The owners name is Jeff Bilyeu at Advanced Industrial Engines, in Springfield Missouri. His telephone number is 417-832-0076
Tom Regan
05-01-2006 20:07:22
 Re: Wisconsin Robin engine in reply to Roger Creasy, 02-20-2006 17:39:50
I have a Wisconsin-Robin EY44W on a rotortiller and it's a beast. I'm in need of an air filter for it but haven't had any luck finding one. Does anyone know where I can get an air filter for this engine?
Roger Creasy
04-18-2007 15:39:46
 Re: Wisconsin Robin engine in reply to Tom Regan, 05-01-2006 20:07:22
Recently I threw a rod in my Wisconsin Robin Engine due to low oil. I had a mechanic look at the engine and said to fix it would be $300.00 if I did the labor, or $600.00 if he did it. Parts for these engines are getting hard to find and if you do find them, they are expensive becouse these were a low demand engine. MOst people for this horsepower went with Kohler engines. Again I found out from him today that this is a 10 hp motor. For $575.00, I think I will replace with a 9.0hp Honda. But my bad luck can be your good fortune. I have the rest of the engine that is in great mechanical shape. The carbeurator, filter housing and 3 month old filter, bearings, case, pull starter assy., etc. are still good and would make nice parts to someone who has the same engine. If you would like to make an offer on these, please contact me at [email protected]. I can send pictures and my cell phone number if you are interesed. Thank you, Roger.
