Stationary Engines Discussion Forum
Wisconsin Carb Problems
Paul
11-27-2003 13:19:04
I have an older 8hp cast iron wisconsin that ran great when I put it into storage. I'm trying to get it runnning for a go-kart for my grandkids for Christmas. I can get it to fire when I use starter fluid, but can't seem to get it to take gas. It has a gravity feed gas tank and the bowl is full. It's not flooding and the plug is dry.
It has a Smith Carb. Any thoughts? Thanks in advance,
Paul
Bill D.
11-28-2003 06:28:18
 Re: Wisconsin Carb Problems in reply to Paul , 11-27-2003 13:19:04
I'm not familiar with the Smith carb but it is possible it might be air locked. The Wisconsin I have is a AKN on an old CH&E pump set up. It has a Tillson carb on it and I've had the same problem with air lock. If I loosen the top of the bowl on the carb, gas is let in and it runs fine after that. You may also have some kind of obstruction somewhere along the too. Just my 2 cents for what it's worth.
Paul
11-28-2003 08:57:25
 Re: Re: Wisconsin Carb Problems in reply to Bill D., 11-28-2003 06:28:18
Thanks Bill, I'll give that try. I've already taken it apart and blown it out and everything seems clear,
Paul
