Stationary Engines Discussion Forum
Old BS engines
Kent of SW MO
11-11-2003 11:57:11
Bought a K model and a ZZP at an auction.I already have both running. K was built May 1935. ZZP built May 1942, Say special in the model number area with a star inplace of the "a" in special. Also had remains of sheilded/ sealed aircraft plug wire. I have replaced the wire with a newer sheilded plug wire and spark plug. What are these engines worth?
Baggsy-Wy
11-11-2003 18:00:02
 Re: Old BS engines in reply to Kent of SW MO, 11-11-2003 11:57:11
Kent, good to hear ya back out here again. Congrats on your engines, sounds like you know what you're doing with them. It seems like the old Briggs aren't worth alot, but they're worth more than they were 10 years ago. I would think the K in good shape would bring $150 or so, and the ZZP maybe $175 to $200 in good shape. The Z's were the biggest Briggs in their time and I think they are way underpriced at this point. Does yours have the oil-bath air cleaner on it? I'm the guy that has the Z with zero compression that you told to remove the valve plate behind the carb to check. Now I'm starting to get interested in it again, now that you have yours running. I'll have to drag it into the shop to work on, but I'm curious just where the plate is and how big it is? I was thinking I'd probably have to pull the head on it. Might not be as bad as I thought...Thanks for any help...Baggsy
Kent of SW MO
11-12-2003 11:18:44
 Re: Re: Old BS engines in reply to Baggsy-Wy, 11-11-2003 18:00:02
I have the oil bath air cleaners. Both of my engine are complete.
Kent of SW MO
11-12-2003 11:10:15
The plate which is behind the carb. covers the valve spring chamber. You will be able to tell if the valve are working by watching the valve spring. The exhaust valve is the one that normally stikes because little oil at shut-down after running and if the valve is in the open position when the engine stops. The the valve stem will rust causing the vavle to stick. This would not happen if the engine is oiled down for storage, but most people do not do this.
Baggsy-Wy
11-11-2003 18:30:56
Here's a ZZ manual on-line for your viewing pleasure...
http://www.semidiesel.com/olm/pdfs/brigszz.pdf
Kent of SW MO
11-13-2003 07:52:23
 Re: Re: Re: Old BS engines in reply to Baggsy-Wy, 11-11-2003 18:30:56
Baggsy, Send me your E-mail adress so we can talk more directlly.
Kent of SW MO
11-12-2003 11:15:31
I have the B&S Service Manuel for Out of Production Engines P/N CE8069-5/00.
