Stationary Engines Discussion Forum
value
Jim
09-28-2003 18:58:11
Hello, I have a 12 h.p. westcoast engine manufactured by the Sterne Bros. of San Diego,ca. with 48 in. flywheels. Some parts are missing. Missing part are the governor,crank guard, some oilers ect .The fly wheels are in bad shape alone with the shaft that operates the igniter.I was wondering if any one would know the value of this engine. thanks Jim
Mike Tyler
10-02-2003 15:03:37
 Re: value in reply to Jim, 09-28-2003 18:58:11
Jim, I would guess around $1000 for what you discribed. If the flywheels need to be re-manufactured, that will run someone about $2 a lb for the casting plus $400 each for machining. Governor will have to be made since none are out there. Ignitor will need to be made as will the sideshaft. The cross helical gears are fairly expensive as well. Hopefully, the cylinder will not need sleeving. Good luck with this engine, it will be a long term project. Mike
