Todd Adams
10-16-2003 03:28:46
Re: Re: Wisconsin engine needs help in reply to deano, 10-15-2003 18:42:02
Hey, Figured out the problem, but now I have more little problems. One of the people I had work on it, ran a wire from the spark plug to the "Kill Switch" Everytime I took the plug off and set it on the excaust and turned the key to check the firing it fired. So I done away, with the wire he had run to the plug, and turned the key, It fired right up, First Try!! Now my other problems, While digging my ditch last week for my city water, I noticed my Excaust pipe was cherry red, What's this a sign of?? I took it off, thinking it may be stopped up, but it appeared allright. (Believe I'll leave it off though) #2: While digging my neighbors ditch (city water) the chain/teeth bogged down (under a load) and it died. I couldn't get it to start back, so my uncle dragged his booster over and boosted it off, started then. Without boosting, it sounds like the battery is turning the starter fast enough, to were it should start, but it don't #3: I have oil/gas?? coming out of the suction line right before it goes into the carburator. What's this a sign of?? It looks like super thin oil, and smells like gas.... Welp, Figured I'd throw some more questions at ya. Thanks for all the replys. I'll try putting a little oil in the spark plug hole. Thanks again.
